20 Most Recent
Lakewood HV9 Floor / Box Fan Questions & Answers
After 8 months, fan will
The latest Jameco electronics catalog (www.jameco.com) has a 5 uF 370 volt motor-run capacitor for $1.95. It may however, be too physically large to fit in the motor case. Hope this helps!
Lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Lakewood mini tower fan model mtf-15. The oscillating fan stopped oscillating. How do you repair it?
Whether the fan has a dedicated oscillation motor or is driven by an extended shaft from the main motor, there is usually a button or switch to disengage the oscillating function. If this no longer has any effect the only cure is to dismantle the machine until the fault is discovered and then if a repair is possible - repair it...
Most domestic fans have no spare part support, mechanisms have a limited life and if "handyman" repairs aren't possible it is considered a throw-away item.
