20 Most Recent
KitchenAid KWCU265HSS Kitchen Hood Questions & Answers
Schematic for AP3105889
What is it you are trying to do? Are you trying to repair the one you have so as to not purchase a new one? Do you need help hooking up the correct wires? Your question is unclear so any additional detail would be helpful.
The blower motor hums but
The little fan is going out.you can disconnect the power to it,and remove it,to see if you can clean it,then it might start working,do not oil it,it will catch fire,but I suggest to replace it.I hope this is helpful,if so,please let us know,thank you.
For the last few months
It is possible that if you can get the motor out of there and get some WD-40 worked into the bearings you can get it running again...
turn it so the shaft is pointing up and then spray the WD-40 right on the shaft and let it run down and into the bearing...
once you get the shaft spinning more freely then place a few drops of light motor oil or sewing machine oil on the shaft and let it run into the bearing before turning the motor from the shaft up position and reinstalling...
heatman101
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
