Every time we get a telephone call, it cuts our internet service. Comcast says we need to change the channel on our phone, but I don't see any button on the phone or answering machine that says "channel." It's a Uniden Power Max 5.8GHz.
We have a two Panasonic Digital 2.4 GHz GIGARANGE cordless phones and one VTEC 5.8 GHz cordless phone. All of them interupt our Actiontec DSL Gateway 54mbps wireless internet router. We are at a loss and do not no what to do so please help. We have a two Panasonic Digital 2.4 GHz GIGARANGE cordless phones and one VTEC 5.8 GHz cordless phone. All of them interupt our Actiontec DSL Gateway 54mbps wireless internet router. We are at a loss and do not no what to do so please help.
You can't post conmments that contain an email address.
The owners manual should tell you how to do that. If you don't have the manual, search online for the type and model of phone you have. There should be a way to get the manual mailed to you or download it online.
I assume you are using a Comcast modem that you plug your phone into.
Does a wired connection to your router work when you get a phone call or just wireless the wireless is cutting out? If both cut out then this problem is on Comcast's side. You can call them using 1-800-COMCAST to have them fix the issue.
If the wired connection works but wireless does not, I would guess you are using a cordless phone that is running on the same frequency your wireless router is. If this is the case, you can change your router's configurations to operate on a different frequency. This can be done by opening up your internet browser and entering the router's configuration menus by using a URL(address) of 192.168.1.1 (possibly 192.168.0.1). Once you are in the configurations, look for options for wireless frequency and change them to something else.
If this does not work, I would suggest calling Comcast because the problem more than likely resides on their end.
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
The DSL Filter is only needed if you have a telephone and DSL service coming through on the same line. You are using Comcast digital voice, are you using them for cable internet as well?
I presume you are. then I would say you dont need the filters.
If you still have DSL and home phone then use the filters on the phone
Note : The steps below are applicable only for Belkin routers.
Open an Internet Explorer window on your computer and type in http://192.168.2.1 in
the address bar. This will take you to the Belkin router's web based
configuration page. If you are not able to open the page click here.
You will get a login page. Leave the password blank. Click Submit .
On the left side of the page, click Channel and SSID below Wireless .
The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
Click Logout in the top right hand corner.
Note: The wireless card in the computer will
automatically detect the change in channel number on the router and
will update the channel on the card.
CauseYou
are not able to connect wirelessly mainly due to environmental
interference. When the wireless channel is set to auto, the router will
cycle to though channels when it detects significant interference. When
the router changes channel the wireless connection will reset itself
and disconnect all wireless clients connected to the router.
SummaryWireless signals
are prone to interference from cordless phones and electrical
appliances (e.g., vacuum cleaners, microwave ovens). This is the reason
wireless connections can drop. This article explains how to overcome
frequent wireless disconnections by changing the channel number
(frequency) on the Belkin router.
This is a case of an incorrectly fitted or faulty filter.
One of these should be fitted to every socket where a telephone is used, as they enable land line and the adsl connection to run at the same time.
i forget how to change the time on my uniden phone answering system
