SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is [email protected]
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
SOURCE: I have a WBR-2310 D-Link wireless router.
1. Reset the cable modem. There should be a reset button on the rear... hold it in for 10 seconds. If there is no button, unplug it (pull the backup battery too, if applicable)
2.Login to your routers web interface. IP address should be 192.168.0.1
3.Click the status tab.
4.Under WAN>Connection> click "DHCP Release"-----> Then click "renew"
If that does not work Return to the routers web interface. Click the setup tab ----> click "Manual configure"
Under DHCP Internet connection type> click "clone mac address"
Do NOT forget to save your changes before switching tabs in the routers web interface.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
What internet service are you using?
Is this service using a router of its own?
Is the service set up PPPoe on the modem?
