My Casio Camera EX-Z750 ... it can't load the photo from Camera to Computer .... so I don't know how to solve it .... Please let me know.....Right now I want to Print the Pictures but It didn't work
Thanks in advance ,
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I don't know about your software problem, but there is an alternate way to down load most cameras that use SD memory cards. Several stores carry card readers that output to USB connectors. Just remove your SD card , install it in the card reader and plug the card reader into the USB connector on your computer. Your computer should recognize it as just another input, and you can copy the JPEG picutre to your computer.
I ended up solving this by briefly removing the memory card and the battery from the camera, then reinserting them. This seemed to re-set everything and it then all worked well!
Did your camera come with a cable to hook it up to a computer?
Or does it have removable memory stick media? Either way we can get you through this.
Assuming you still have all materials that came with the camera including a cd, and usb cable, make sure you have loaded the cd and software into your computer first. Then plug your cable into the camera port, then into the usb on the computer.
Drivers should have been loaded into the computer to recognize the camera as a device. You should see a prompt to save your photos to the computer. If not then you will have to manually browse your computer to see the device as a new drive, and open the folders to find the photos. You can then copy and paste them to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open.
You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
