Washing Machines Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool duet sport washing machine will start a cycle but it does not go through the whole cycle and it shuts off and the door stays locked and seems to happen all the time anymore. There are no codes that will come up when this happens. Any ideas on what the problem is?
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Answers
94
Questions
Helped
174381
Points
214
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 79 Answers
  • Posted on Feb 28, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
79
Questions
5
Helped
169384
Points
102
1helpful
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
We have a whirlpool duet sport washer, the machine is powered on as evidenced by the lit up control panel's LED but when we try to run a cycle, the machine refuses to start and after a couple minutes it...
do you hear the door lock assymbley locking if not then either you have a bad control upper board central control unit uper grey board located top back of washer ........or bad door lock assy
1helpful
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
1helpful
2answers
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
I have a Whirlpool Duet Sport Washer that will not start but stays in the Add a Garment stage with the door lock lamp lite. The door locks and I am unable to unlock the door and the cycle will not start. I...
Each time there is a major part swap - replacement - they switch the number to differentiate between the boards.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
5helpful
2answers
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
