Question about Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Posted by kshack7313 on
Prakash R
    President:
  • 1,382 Answers
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Posted on Jun 20, 2010
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F22 code ?? duet locks but will not run
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F22, washer is locked and will not unlock
IT is a defective lock, unplug the machine for 30 minutes and plug it back in. Then once the door opens replace the door lock and all should be well
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Mar 28, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
475 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
