1993 Toyota Camry V6 Logo
Posted on Aug 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'93 Camry V6 problem with door locks
Another problem that I have with my '93 4 door Camry V6 is that the automatic door locks for the front doors no longer work, although the rear doors are locking fine when I push the master door lock button. The front locks move slightly but don't seem to have enough power to actually lock? Any suggestions appreciated.
  • 2 more comments
  • wizecards Aug 20, 2008
    Are the power lock actuators fairly accessible or do they need extensive labor to get to?
  • cyoungssa Nov 07, 2008
    I have a 2000 Camy and the front door automatic locks no longer work. Having read the above, what is an actuator, where do I get one (them), and about how much?
  • Anonymous Mar 16, 2014
    front and rear passenger doors will not lock when button pressed on key
  • Anonymous Mar 30, 2014
    My door locks stop working 93 chavy suburban were the fuse st I cent fine it
Anonymous
Level 3:
President:
  • Master 1,450 Answers
  • Posted on Aug 20, 2008
Anonymous
Master
Level 3:
President:
Answers
1450
Questions
Helped
797432
Points
4747
Your power lock actuators are bad in the front doors.
  • Anonymous Aug 20, 2008
    the door panels will have to come off they are built into the door latches. depending on your mechanical level it can be aggravating due to the lock/door latch rods having to come off
1992 camry key won't open doors
The key or the lock or both may be worn. You will need an auto locksmith. It is also possible that the lock linkage inside the door is broken.
My 1993 toyota camry's automatic door won't lock. when i press the lock button or use the key, it just click back to open. what could theproblem be?
it could be a bad door switch or the key switch in the ignition, it thinks the key is in the ignition so it doesnt let you look the door it unlocks it, may need to replace the ignition or dissable the sensor in the igniton by cliping the wiring .
Lost power to power windows, door locks and sun roof.. I can not find the correct fuse that i think has blown. I have looked everywhere and all of the fuses are just fine.. 1992 Toyota Camry V6 XLE
Most likely a broken wire in the harness from front drivers door...open up and cut off the rubber boot and fix broken wires...they tend to break after a few thousand opens and closes...then wrap with electrical tape to replace the rubber boot...Lee
2helpful
2004 Camry front driver door lock will only lock/unlock with key, the remote and lock button locks and unlock all locks fine except for the front driver side door lock. You have to either use the key or...
Remove the door panel and reconnect the plug going to the front driver door lock or, if you can hear the motor trying to engage the door lock cam when you press the lock/unlock remotereconnect the door lock lever bar
Installing power window on 1993 toyota camry
Take the door panel off. Disconnect the window and tape it up. Remove the regulator out off the door cavity.
2helpful
2answers
1999 Toyota Camry door lock and unlock issues
I believe this was done as a safety feature. It stops a potential car hyjacker from sneaking in the passenger door when you open the driver door. I know recent Hyundai models are set up such that if you turn the key in the driver's door once it only unlocks the driver's door. If you turn it twice in quick succession it unlocks all of the doors. Maybe the Camry is set up the same way.
1helpful
93 Camry v6 LE Door Locks
I have sent you the wiring diagram. Please respond if you have any questions.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
