It is probally in 4 wheel drive. It is supposed to **** while turning in 4 wheel drive because all 4 tires are trying to turn at the same speed and when you turn one tire slows down and the other tire speeds up but it cant in 4 wheel drive so it skips or jerks. If there is also a clicking noise the CV joint might be going out.
SOURCE: Front axle making noises
change the axle it will be a cv joint and should only take a couple of hours to change out
SOURCE: Front End noise and vibration
Check the U-joints and axle baerings. But its most likely because the truck is in four wheel drive.
SOURCE: 1995 2500 silverado front axle 4x4
from 88 to 98 everything mechanical was the same. the only difference was the vortecs in the late 90's
SOURCE: noise from front end more so when you are turning
You also could have received a bad axle. Sometimes the rebuilds don't hold good tolerance and can make the same noise you are trying to get rid of. Is it full-time 4wd? Maybe the driveshaft ujoint also.
SOURCE: 1999 Chevy Silverado with clunking/jerking in the back
It sounds like your 4WD is still engaged and you need to have it serviced. It's common for the 4wd to get stuck in the on position with the button pushed to the 2wd mode. As you turn the front wheels are binding with the rear wheels. There is a vacuum switch on top if the transfer case on the drivers side that may have gone bad and needs to be replaced. You can pick it up at Auto Zone for $25.00 and $85.00 at the dealer, there is three vacuum hose attached to it that needs to be disconnected and then the switch can be un screwed from the transfer case like a spark plug.. Good luck and hope this helps. keep me posted, be glad to answer any question you may have.
