Helpful to know meaning of 'dr.' More helpful if fix tips were included too.Helpful to know meaning of 'dr.' More helpful if fix tips were included too.
You can't post conmments that contain an email address.
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
