Im taking a look at your userguide at www.bang-olufsen.com. Im sure your aware of what kind of tv this is, its VERY expensive and complex. Im on a dialup connection and Im downloading the pdf for you, it may take awhile. Okay- find and select ZONES on the remote and choose where the tv is in your house from there your tv will come up with input sources on the screen , choose which input your using and then it should fire up, I recommend going to the b and o website and setting up an account, its free and you can take a look at all the way cool stuff they have.
good luck
J
See if you can get helped from relative link below
http://www.lcd-television-repair.com/
Power supply board may be faulty. Since troubleshooting DIY needs some experience better take it to an authorized service to repair.
Nice TV set. Try first unplugging the tv for ten minutes, this quick hard reset will drain power from tv, and sometimes it solves the problem when TV is freezing on startup.
If this soes not work there must be a service reset procedure.
