Video Game Consoles & Games Logo
Posted on May 30, 2011
When i try to connect to a proxy on my PS3 i get the 80710092 error code, how can i fix this?
David H. Peterson
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 10 Answers
  • Posted on May 30, 2011
David H. Peterson
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
10
Questions
0
Helped
4857
Points
28
VERY QUICK AND VERY EASY! JUST GO TO:
http://www.wn.com/ps3_error_80710092 and click on the first choice in right column and you will find your answer on a video guide that you can play as many times as you need and its FREE.
I hope this helped. GAME ON!
How To Fix Outlook Error 8?
Outlook is unable to connect to the proxy server, probably because of certificate issues. You need to correct the certificate problem...see the link for details. https://technewskb.com/outlook-is-unable-to-connect-to-the-proxy-server-error-code-8
1helpful
2answers
Windowsupdate 80072ee2
In order to resolve the matter at first, you have to know more about the error code in detail. Windows Update Error 80072ee2 generally arises when you try to connect to the windows server for the purpose of downloading the latest updates and the system is unable to establish a proper connection. Well, I have the most advanced methods to fix Windows update error 80072ee2 with all appropriate explanations.
Methods to Troubleshoot Windows Update Error 80072ee2
Method 1: Check for the Internet connection
Method 2: Check for all accurate proxy and firewall settings
Method 3: Reset the system proxy server settings
Hopefully, you will be able to fix the bug on your own with the help of the above methods.
2answers
I want to check my phone updates but it is coming error as 80072ee2 why?
make sure Ur phone is connected to internet via strong connection,WIFI is preferred .
there should be enough space in the phone to install the update.
try restarting the device.
at last try factory resetting device (do take the backup first),then update ,will work for sure.
2answers
When i used to check updates......... it is coming erroe as 80072ee2
first try to check for updates using mobile network , then update thru wifi . sometimes , wifi shows error when u check for updates. i also experienced this same problem
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
3helpful
When trying to download Google Chrome, error code 130 comes up. It say's that I'm not connected because of proxy server connection problems. I am currently connected with Mozilla.org through the...
have you tried with Internet Explorer!! Its the least thing you can do to help you over come the problem of proxy connection!! try this out and let me know if it works or not and if you are still having the same problem please let me know..
1helpful
2answers
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
1helpful
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Errors found:Code 8024402C Windows can't check for updates
Description:
The 0×8024402C error code occurs because an incorrect character exists in the proxy override settings.
Possible Cause/s:
1. Incorrect character exists in the proxy override settings.
2. A misconfigured Proxy/Firewall can cause this problem.
3. You are trying to access Windows Update using VPN. The website and Automatic Update may not function properly.
4. The corporate environment does not have autoproxy implemented.
5. Your workstations sits behind a Microsoft ISA server.
Resolution 1:
Remove invalid characters from the proxy exception list and then clear the proxy cache:
1. Open Internet Explorer.
2. On the Tools, select Internet Options.
3. Click on the Connections tab.
4. Click on the LAN Settings.
5. Click on the Advanced button.
6. Please delete any entry in the Exceptions section.
Next, clear your proxy cache:
1. Click on Start, and then click Run.
2. Type cmd in the Open box to get a DOS prompt.
3. Type proxycfg -d at the command prompt, and press Enter.
4. Type net stop wuauserv at the command prompt, and press Enter.
5. Type net start wuauserv at the command prompt, and press Enter.
6. Now try the site again.
Resolution 2:
Reconfigure or update your firewall program:
1. Double-check the Proxy/Firewall settings. Add the following urls to the exception list within your Firewall/Proxy:
http://*.windowsupdate.microsoft.com
https://*.windowsupdate.microsoft.com
http://download.windowsupdate.com
Resolution 3:
VPN and Proxy.
Autoproxy is not picking up the wpad.dat proxy configuration file to determine the proxy to be used for the target URL. Thus we are going with no proxy!
1. Try to access Windows Update while not using VPN connection.
2. Use the proxycfg tool to specify a proxy server to use (proxycfg.exe -p <proxy server>). (contact your network administrator to find out the name and port of this proxy.)
This is every possible cause and solution for this error code and how to fix it. Please take the time to rate this Fixya for me for spending an hour researching every possible cause and solution for this code you posted for free, even if you don't figure it out. The solution to your problem is definitely here so read it carefully.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
