Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
Hewlett Packard 49.XXXX Errors
I hope this will be of assistance to you, any repairs under taken are at the owners free will.
Hello, the dreaded 49.2F9D Error Turn Power On/Off and other related 49 Errors.
This tip relates to the Hewlett Packard P3005 Series Printer - General reference to most HP Laser Printers
There have been many reports of this error in the HP genre of laser printer. This is a generic fatal error; the root cause is undetermined in most cases. It could be related to an application "corrupt data" or faulty printer firmware, or the formatter board or other associated hardware or accessory. The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. A new firmware file can be found here. P3005FIRMWARE
Pay close attention to PDF files with embedded JPEG files.
Pay close attention when printing Emails or Web Pages.
In rare circumstances the fuser has been reported to cause the 49.2F9D error. (P3005 specifically)
*** Further Reference Material MoreOn49Errors ***
Contact a local HP Authorized Service Center for further assistance.
