You will need to manually unlock the door... remove the top two screws in the back ..reach way down at the bottom of the door lock there is a pull down on the lock it will release the door... if your arms are not long enough use a bent coat hanger....once you have the door open .. remove the wire around the gasket .. remove outer gasket unscrew door lock. unplug wires and replace door lock...
hope it helps
Door wont unlock
Door wont unlock
