Posted on Aug 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fax and function
How can I activate the walkup fax function fro Toshiba esolution 120 ? also what kind of driver do I need to activate network scan functions of the all-in-one unit? My contact info is [email protected].
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Oct 07, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
Helped
75068
Points
150
I believe that the scan feature is standard on this model. The driver is on the CD that came with the machine. If however you don't have this, you might be able to google it, and find a driver. However, you will need a fax board to use the fax feature.
c
1helpful
We have this copier and would like for it to print/scan/fax as its model number implies it will (MF). Do we need to purchase a "brain" or network card in order to get the other functions to work or is...
do you have a "scan" function in the menu keys also a fax button. If not it may been just a copier. What is the make and model number, and no you do not need a network card.
1helpful
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
1helpful
How to configure scaner of my toshiba 353 ,to scan on my pc
In order to allow the e-353 to scan to eMail, and PC, you must have an enabler (Scan, or Scan and Print), either on will allow you utilize the scanning function through network(PC and copier must be in the same subset).
Or you can use the USB connection, just install the unity from the CD, or download it from Toshiba.com
http://business.toshiba.com/support/downloads.jsp?site=usa#Utilities
Choose the e-bridge full installer, burn the ISO image to a CD.
2answers
I have a Toshiba E-Studio 350 and i want to download its printer driver because i wnat to use it as a printer on my computer but i dont have its driver CD so kindly send me link for download it thanks
business.toshiba.com You'll be able to find your drivers there. However, if you don't have a print or print/scan dongle (activator) on your machine, network printing will not work.
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
7helpful
2answers
How do I create/set up the IP address for a toshiba estudio 353 copy/fax/scan unit?
On control panel press "user functions" , then select admin tab, press password and type password (default is 123456),press network and then ipv4. There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin.
Lexmark 6150 all-in-one printer
not just the driver, you need to get the software fo rthe printer in order to fax and san. they are different function aside from print.
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
