20 Most Recent Toshiba estudio 255 Copier Questions & Answers
dose the key pad works??
Toshiba estudio... | Answered on Oct 06, 2018
Check the separation roller on the feeder unit, replace it if grip not good...
Toshiba estudio... | Answered on Oct 04, 2017
U have to Reset PM counters in this parts process unit parts and developer material.
Toshiba estudio... | Answered on Jan 30, 2017
Have you made sure you changed the drawer size setting on the copier as well as the physical size of the drawer?
Toshiba estudio... | Answered on Jul 26, 2016
U have to purchase printer and scanner kit
Toshiba estudio... | Answered on Jun 26, 2016
U have to Reset PM Counters in this parts process unit parts and developer material.
This is a fusser related error code..
Toshiba estudio... | Answered on Mar 27, 2016
Toshiba estudio... | Answered on Feb 24, 2016
[F105] HDD other error
Check if the connectors of the HDD are disconnected.
Check if the connector pins are disconnected or the wires of harnesses are broken.
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Toshiba estudio... | Answered on Jun 12, 2015
You should try to get the error code from the machine, and then include it in your post. To get the error code: press [CLEAR] button and [8] button simultaneously, and copy down the results. Post the error code in this thread to assist you with the correct troubleshooting procedure.
Toshiba estudio... | Answered on Apr 17, 2015
Check manual or tech support. Maybe youtube has video.
Toshiba estudio... | Answered on Mar 18, 2015
Needs firmware update ..
Toshiba estudio... | Answered on Dec 05, 2014
You can reset this by the following procedures.
1. "Off" the copier then press "Start" and "6" keys at the same time.
2. "On" the copier while doing step 1. Wait til you see the display panel change then press "2" key, then "Start" .
3. It will show list of the PM items. Reset the counters then restart the copier..
Help me please how to fix time for periodic maintenance 0180 toshiba e-studio e255
Toshiba estudio... | Answered on Nov 27, 2014
You can create user (email) in address book from copier control panel as well. Then when you press scan, the email contact address will be there to select.
Toshiba estudio 255 Copier Logo
120 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
estudio 255 copy machine updated new
  • Office Equipment & Supplies
