20 Most Recent Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer Questions & Answers
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Toshiba Copier... | Answered on Apr 29, 2019
Did you use the original toner and original drum? Toner high in developer. While pressing [0] and [5] simultaneously, turn the power ON. The following message will be displayed. Key in code [2000] and press the [START] button. The display changes as follows.
Indicates the controlled value of the auto-toner sensor output. Press the Up or Down button to change the value.(245,128)
Please the OK button.
Toshiba Office... | Answered on May 20, 2019
This means that the operating system on the hdd fails to start.
The hdd is probably failing and needs replaced.
Toshiba Office... | Answered on May 17, 2019
CE90 is Drum themistor abnormal
Check the drum themistor & connector...
Swap process unit, if still giving same error, probably LGC board issue
Toshiba Office... | Answered on May 14, 2019
Replace paper feed/separator rolls. Blow jam sensors out with compressed air. Check fuser picks and rollers.
i highly doubt a copier photo would be acceptable to the govt for a passport although you can try. worst case they reject your application
Toshiba Office... | Answered on May 03, 2019
U need to check fuser unit, especially the actuator exit sensor is not deformed, following by cleaning exit rollers.
Toshiba Office... | Answered on Apr 28, 2019
Do you have firmware?
you have to update firmware using pc update tool.
Toshiba Office... | Answered on Apr 21, 2019
Toshiba Copier Gm 2040 Print Scan Enabler E Studio 520 600 720 850 Printer Logo
2 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
amir hamza
amir hamza
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
f101 error toshiba estudio2040c
  • Office Equipment & Supplies
