Lexmark X544dn All-In-One Laser Printer Logo
Posted on Apr 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
900 Firmware error on lexmark x544 what does this mean
Anonymous
Level 3:
  • Master 1,179 Answers
  • Posted on Apr 14, 2011
Anonymous
Master
Level 3:
Answers
1179
Questions
Helped
246371
Points
3035
Within your printer there is a micro-processor and a memory chip. The Firmware is a piece of software that is loaded to a memory chip.
Error of the software has occurred, you therefore may need to flash the firmware of the printer.
Find the Firmware on the Lexmark website, be sure to get the EXACT one for your printer.
Remember a failed attempt will render your printer useless, contact a professional to flash the fimware if you are unsure.
Thanking you
damnor01
Anonymous
Level 3:
Genius:
  • Master 1,087 Answers
  • Posted on Jul 07, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1087
Questions
0
Helped
491005
Points
2129
If the 900 error occurs only when the printer is receiving information from a network or computer, you should first contact your local helpdesk or your software/network support. This is because a communication issue with your network or software is indicated. If the error occurs when the printer is idle or not connected to the network or PC, however, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the issue. The first thing to check is the base printer.
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/nKTCSU
For further assistance, please call Lexmark Technical Support.
Creative Tech
Level 3:
  • Master 1,719 Answers
Creative Tech
Master
Level 3:
Answers
1719
Questions
Helped
636071
Points
5906
Lexmark x544 Firmware
Firmware update instructions:
  1. Download the appropriate update file
  2. Unzip the downloaded file
  3. Read the README file (located in .zip file) before updating
Hope it helps! Good Luck!
CreativeTECH
1 Related Answer
willem52
Willem.
  • 359 Answers
  • Posted on Aug 24, 2011
SOURCE: I have a lexmark X544
THIS PAGE may give you more information about this Lexmark error code.
Lexmark X544 standard bin is full
In output between rollers you have a plastic parts wich moves. They are the output bin sensor. Maybe are stuck, see if moves.
2helpful
2answers
I am getting a 900 firmware error notice
A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
2helpful
I have a lexmark X204n for 1 month now and gives me the 900 firmware err or to continue ???? what is this ???
Hello and welcome to Fixya!
A 900 Firmware error means that your Machine's Firmware is corrupter.
The easiest way to fix this is to navigate to this link and download the latest firmware for your printer.
You will see something link "Firmware for Lexmark.. at the bottom in the Downloads section.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
3helpful
My x204n had a error.It's '900 firmware error to continue'.Can you help me?
Hello
The easiest way to fix this is to go to link below and download the latest firmware for your printer.
Hope this helps, if so do rate the solution.
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X204N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
4helpful
2answers
When I turn on my lexmark x204n it gives me a 900 firmware error how can I get rid of it and what does it mean?
Don
10helpful
"900 firmware error" on our Lexmark X204n printer. how do we fix it?
7helpful
900 Firmware error
The following link has Lexmark support and troubleshooting steps regarding "Error 900" for X54x:
Lexmark X544 Error 900
I hope this information is helpful.
3helpful
Lexmark T520 I get an error code 900 service RIP software. further 44 p4 notify 001c-0300 page4/bios/fountain/notify.c-223:Inv eot:0 what does that mean, do I need a new engine board, or can I clear this...
Typically the engine controller circuit cards go bad. the firmware (software) get corrupted. you can try upgrading the firmware but ordinarly you cant clear the 900 service fault to try that. So your only solution is the replace the engine circuit card.
1helpful
2answers
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
