If you're doing Printer Sharing, make sure that your printer is connected to the computer that is on the same Workgroup as your other computers in the network. I hope this helps.
The Lexmark x2600 requires a power cord to operate. Its power supply assembly is contained within the printer, so the power cord plugs directly into the printer.
The 1203 error indicates a short in one of the cartridges. Follow the steps below to fix the problem:
Open the printer cover and remove both cartridges from the carrier
Close the cover
Unplug and re-plug the printer into the power source to reset it
When the printer turns on, re-insert one cartridge first. Close the cover and check for errors
Then re-insert the other cartridge. Close the cover and check for errors.
Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the new one is faulty.
The power-cord is a "standard" power-cord -- nothing special.
Note the "figure-eight" plastic connector at one end.
So, look around ("thrift" stores, "dollar-or-less" stores, local electrical supply stores, and finally the "big-box" stores like BestBuy) -- it should be less than $5.
Try a couple of steps :-
1.Make sure the wire is plugged in and printer is turned on
2.Go to control panel - printers - make sure the printer is set to default.
If the above steps are done, try the following :--
Open control panel - go to add/remove programs - uninstall everything that says Lexmark 5270
Click the link below to download the printer driver, can use help guide for the driver installation.
Make sure the Printer's IP Address is range with the IP Address of your network. Note: - Try to power cycle your Printer once after you setup the Printer settings.
I recently had all the lexmark 5270 software erased from my hard drive and now my computer doesn't recognize my printer.Is there a cite that I can go to download the software?
lexmark 5270 power light flashing
