Anonymous Posted on Aug 05, 2008
Can't get the cartridges into the printer - HP Office Equipment & Supplies
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
15
Points
Asked help from a friend who owns an identical printer. Her advice came FREE OF CHARGE.  Think it would be appropriate if you advised consumers early in the process of seeking FixYa's help that it is NOT a free service.
My epson p50 printer error: out of cartridge
Epson printer is out of cartridge or Epson printer won't recognize ink cartridge When you haven't properly installed cartridge, Outdated printer drivers and more. Follow the steps to fix the Epson printer out-of-cartridge issue:
·Remove and Reinstall the ink cartridge
·Clean the chip on the printer ink cartridge
Read the following steps to fix the Epson printer won't recognize ink cartridge
3answers
Can not recognize ink cartridges
remove all cartridges and unplug printer for 5min.place cartridges back and plug in printer.good luck
2answers
No cartridge error message
yes, if no cartridge into printer, device will appear error message, but if have cartridge into printer, printer still appear message, it most likely your cartridge problems
Regards
3answers
Printer doesn't recognise new ink cart
Dear friend,
Try changing another new cartridge with just one you replaced.If it's working then problem with the cartridge,not then there may be a problem with the printer Logic board or cartridge detection chip.
2answers
How to change the inkjets
  1. Open the top panel of your inkjet printer. You should be able to access the ink cartridges once the top is open. Some printers will reposition the cartridge carriage to provide you better access.
  2. 2
    Remove the old cartridge from the carriage. Depending on the printer, you may need to press down on the cartridge and then pull outward to remove it. Other printers may require you to lift the cartridge out of the printer.
  3. 3
    Unpackage the new replacement cartridge completely. New cartridges will often include plastic strips and protective packaging that must be removed before you can insert the cartridge into the printer.
  4. 4
    Insert the new cartridge into the printer. This will be the reverse of removing the old cartridge.
  5. 5
    Close the top panel of your inkjet printer and allow the printer to detect the new cartridge. You should now be able to print using your newly changed inkjet cartridge.
I have a Lexmark P4350 printer. Just bought new manufactured ink cartridges. The black cartridge works fine. The tricolor cartridge won't print at all - I removed the tape, cleaned both the printer and the...
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
1helpful
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
Affected printers
This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
Explanation
The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
Solution
Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
Cartridge compatibility chart
NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
2helpful
Replaced ink in printer with generic ink cartridges and error message 1203 came up.
A person might notice that buying new, name brand, ink cartridge for printer rapidly becomes quite an expenditure. Nonetheless, there are quite a lot of different methods to find the equal quality standard for a alot lower price. Your primary options are: name brand (OEM) ink cartridge for printer, matching generic ink printer cartridges or remanufactured ink printer cartridges.
When you are purchasing a replacement photo printer cartridge, consumers do have choices. It’s frequently assumed that shoppers are required to buy the expensive, name brand, cartridge for laser printer from the manufacturer, or the service contract will become void. Their belief merely is not correct. By law, the use of compatible replacement inkjet printer cartridges does not render null and void the printer makers guarantee. In truth, you can choose to get less pricey compatible cartridge for laser printer, or remanufactured cartridges, often with a realized savings of between 40% and 75%. All chief ink laser printer cartridge brands have matching versions, including IBM, and Xerox.
Name Brand Inkjet Cartridge for Laser Printer
Nearly all major makers of laser printers also create the replacement inkjet printer cartridges that are best matched for their particular laser printers. This option is ordinarily the most expensive, and in a lot of situations it is the lone choice available if you happen to get a new laser printer whose producer implanted computer chips in the ink printer cartridge. The point of this chip may possibly be to regulate the color ink flow, limit the cartridges use, or to standardize the cartridge in alignment. Nevertheless, if you pick out a similar, or remanufactured, cartridge for laser printer, it might not be able to interconnect with the laser printer and may harm the laser copier or cause it to quit working.
Comparable Generic Inkjet Cartridge for Laser Printer
When thinking about purchasing an ink printer cartridge for your laser printer, the key aspect you must to bear in mind is the price. Buying a brand new ink laser printer cartridge will be based upon how much you are prepared to give. You can buy a new brand name cartridge for printer, or you might purchase a new compatible (generic) ink printer cartridge. Both types of ink printer cartridges might provide you with the same quantity, quality and performance you insist on from your printer. The major difference is in cost: a brand name ink printer cartridge might easily cost nearly twice the price of a compatible cartridge for printer.
Compatible (generic) inkjet laser printer cartridges are made to meet OEM (Original Equipment Manufacturer) specs. These makers usually set very lofty standards of dependability and quality and also provide high quality results, regularly exceeding the quality specifications established by the OEM. These cartridge for printer are produced with new parts and are a lower priced option to costly name brand ink printer cartridges.
Buyers might also be surprised to see that the generic comparable cartridge will publish the same amount of, or more, pages than the original OEM cartridge. Largely, this is since certain original OEM ink laser printer cartridges are not filled all the way up. In this situation, a compatible ink cartridge for printer could give you twice the advantage: it reduces your price per cartridge and cost per page by printing additional pages
5helpful
''No Cartridge'' Error
check if the cartridge is a hp cartridge
if no use a hp cartridge
if issue stll occurs
open the cartridge door
remove the cartridge and the papers from the tray
close the cartridge door and turn off the printer
then turn on then printer
you will get a msg install black cartridge
open the cartridge door and put the cartridge inside and the papers in the tray and close the cartridge door
the printer will intiallize and you will get a ready msg on the display of the printer.
if you still get the msg have the printer serviced
2answers
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me [email protected]
k24674
Grand Canyon Tech
Grand Canyon Tech
