SOURCE: HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
SOURCE: My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
SOURCE: HP Laserjet 3600 Fuser
google feedroller and go to their site they have the service amnual on the printer. you will need it if you never done one before.may as well check the corona wire while you are there.
SOURCE: hp laserjet p2055dn Replace fuser unit
That is a job by it self. If you don't want to damage your printer, I'd suggest you take it to an HP dealer pay some money and get it first checked and if so be the case that it has to change, let them change it.
SOURCE: mem check failure replace dimm
Hi<br /> <br /> The formatter board in the printer is faulty. The heat from the chips softens the soldier and makes the joints bad causing all types of misleading errors.<br /> To solve the problem you can try two differant methords, both will endevour to melt the soldier joints back to good.<br /> <br /> Slide the right hand cover to the back of the printer and remove.<br /> <br /> Open metal door to see formatter board<br /> <br /> Disconnect the three wires from the top left of board, they only go in one way so you do not need to mark them.<br /> <br /> Undo the screws around the board and pull the board free.<br /> <br /> Using a hot air paint stripper heat up the reverse side of the board applying plenty of heat to the soldier joints<br /> <br /> Reasemble<br /> <br /> Do a cold restart and away it should go.<br /> <br /> Alternative to the hot air gun you can but the board in the oven.<br /> Trust me on this one it will survive.<br /> <br /> Support the board at the edges on small blocks of wood to stop it from touching the pan<br /> <br /> Pre heat the oven to 180 degrees<br /> (soldier melts around 165)<br /> <br /> Put the board in for eight minutes and then remove, let cool befour touching.<br /> <br /> Reasemble<br /> <br /> Do a cold restart and the printer should work.<br /> <br /> Chris<!-- from fixya rte -->
