Computers & Internet Logo
Posted on Mar 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have cyberlink ultra 5.0 in my computer and I used to be able to burn 8.5 DVDs, but now I'm unable to do so. What is the problem. It burns 4.7 very well, but not the 8.5.
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 84 Answers
  • Posted on Mar 20, 2011
Anonymous
Expert
Level 2:
Filmmaker:
Answers
84
Questions
0
Helped
25895
Points
223
I would suggest using a new program, either there is something corrupted in the installation of the program you were using or your disk drive is broken. A good program (that I use every day) is IMGBurn (http://www.imgburn.com/), it works very reliably and burns 8.5gb (dual layer) dvds easily. It may also be that you are trying to burn on Single layer (4.7gb) disks instead of dual layer, make sure to check the packaging.
2answers
Powerdirector 8 created dvds will not play
when i play my dvd's video it not work video can't display
tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
DVD burns ''successfully''...but actually burns nothing!
What comes to mind is that you are burning to an image file and not your actual burner. Make a small data DVD and name it something obvious such as aaaa. After completion of the disk, do a search for the file and see if it is in actuality on the computer. If it is stored as an image file, you need to select the recorder type to your actual burner.
PowerDirector 7
Try this link at CyberLink.
http://forum.cyberlink.com/forum/posts/list/15/1823.page
Maybe uninstall and try a new version. Try this link for that.
http://extratorrent.com/torrent/1559723/Cyber+Link+PowerDVD+8+Ultra+1830.50+Build+%2B+Updated+Keygen.html
Hope this helps. Let me know how it goes.
JimmyC
Get video with no audio sometimes when playing back DVD-Rs that i've burned, not sure how to troubleshoot this, i'm a bit of a noob when it comes to burning dvds... the lack of audio seems to occur when...
sounds like certain audio files may be corrupt or you just need to use another program. like if your converting them from say .avi ,mpeg, wmv. then i would suggest convertx. It has always worked for me
My Burner has a problem
The problem looks like a native of the drive. There are possibilities of the drive being faulty. As it is still under warranty, I'd recommend you take both laptops to the nearest HP service station for a replacement.
3helpful
Does cyberlink power dvd burn dvds?
cyberlink power dvd is for playing dvd movies, it is not burning software
2answers
Can'y burn avi files to dvd
You should try to burn the .avi files through nero burner.
Nero 7 or 8 will do, but you'll be able to burn only 2-3 .avi files through nero.
3helpful
I have nero 8 cd/dvd burning software help please help
May be nero vision 5 doesn't support, may be some features are not there...try use new versions...maybe it can resolve your problems..
try use Nero 8.1.1.0 (Nero-8.1.1.0_eng.exe) and use these serial numbers:
Nero 8 Ultra Edition:
1K22-0867-0795-66M4-5572-1962-E03C
1K22-0867-0795-66M4-5610-7010-3X5E
1K22-0867-0795-66M4-5620-8058-3113
1K22-0867-0795-66M4-5432-8660-4A63
1K22-0867-0795-66M4-5326-9400-KK4K
1K22-0867-0795-66M4-5380-8700-15A0
1K22-0867-0795-66M4-5464-9289-934K
1K22-0867-0795-66M4-5768-4957-6578
1K22-0867-0795-66M4-5788-1908-90X9
1K22-0867-0795-66M4-5570-9978-0C16
OR
Install Nero 8.3.2.1 (Nero8.3.2.1.exe) and try use this serial number:
7K22-OO1B-11OS-E9SS-SG3E-C7G2-BCM2
Hope it works!
If you satisfied with my contribution, please do support me...
Thank You!
Burning dvd using cyberlink
hello please somone give a seriel for cyberlink power dvd 8 and good New Year
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
