Sony (CDU701) Internal 32x CD-ROM Drive Logo
Posted on Mar 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The computer is detecting the CD rom but the cd rom is not detecting or reading any CDs
Anonymous
Level 2:
Scholar:
  • Expert 169 Answers
  • Posted on Mar 17, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
169
Questions
0
Helped
45720
Points
409
To fix this problem what you can do is to perform the steps below:
- click start > run and type "regedit" w/o qoutes
- once you access the REGISTRY EDITOR kindly open therse folder (each folder contains another folder) make sure to follow the below steps carefully.
- go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
- insed the "class" folder look for {4D36E965-E325-11CE-BFC1-08002BE10318} it is the CD/DVD rom drive.
- at the right part of the registry delete "upper" and "lower" filters name
- once done close the registry.
Go to device manager
- click start > run > type "devmgmt.msc"
- click the + sign beside CD/DVD drives
- right click and select properties
- go drivers tab
- and then select the button uninstall the driver
- RESTART THE COMPUTER
After restart all should be fine now.
Cheers . . .
Anonymous
Level 3:
  • Master 1,591 Answers
Anonymous
Master
Level 3:
Answers
1591
Questions
Helped
414100
Points
4899
The laser is probably burned out or the spindle motor isn't turning.
With the price of these units, I'd just replace it.
There's not much you can do to fix either problem anyway.
A CD ROM (hard to find, but some places still carry them) can be had for $5 or $10.
For just a bit more, you could get a DVD burner.
2answers
My sony CD Rom problem is that the computer is detecting the CD Drive but the CD Rom is not detecting the CDs
then you should clean you cd rom using a cleaner and stil if it doesn't respond you have to change the ROM
Samsung Octoedge CD RW/DVD ROM detects CDs but not DVDs.
MY dvd writer is reading DVD disks sometime and somtimes it could not making any response.what is the problem about this i dont know how to fix this problem.
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Will not read any cds or dvds
First you check from bios your CD-ROM is detected or not. If it is detected then you can clean the cdrom lence.if it is not detecting then it is a hardware problem. Then you can repaired it from service center.
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
DVD not getting detected
Hi, i have LG GCC4522B CD-RW/DVD-ROM Combo Drive and my problem is that i could open & play CDs. However when i insert DVD the drive doesn't detect the DVD and it shows no DVD in drive or blank. I checked the region setting which is 1. Is it the problem of region setting if so is there any solution for this. Expecting your valuable solution in this regard.
Thanks
Moses
Does not read cd's
the cd you inserted was not compatible with your cd rom. inorder to read all cds you must use cd roms that supports up 60x speed your only have 24x speed thats y it cant read cds that has above 24x.
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
No playing CDs
go to website of bell computer 1. find the latest BIOS and download it to your computer 1. find the latest driver for your CD model and download it Good luck!
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
