Question about Acer (91.49C37.001) CD-ROM Drive
Will not read any cds or dvds - Acer (91.49C37.001) CD-ROM Drive
Posted by carolanfreem on
Anonymous
    Master:
    Sergeant:
  • 460 Answers
First you check from bios your CD-ROM is detected or not. If it is detected then you can clean the cdrom lence.if it is not detecting then it is a hardware problem. Then you can repaired it from service center.
Posted on Dec 18, 2009
3helpful
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
I have purchased a tsst ts-t633a external dvd +-RW drive to link with an acer aspire a0531 netbook. The drive will read and write CDs but not recognise DVDs. Can anyone help?
You need a software made for DVDs which you can use for the CDs to.
To read DVDs (and CDs) use Power DVD.
To burn DVDs (and CDs) use Nero DVD. You may purchase them almost to any PC shop.
This is just an example. You may find some free software on the Internet but if you are not used with this I suggest to ask a friend to help you or to buy a software as I have already said.
My writemaster sh-w162 will reconise cds but not dvds can you help, im using library computer .it will copy or burn cds not dvds
actually the problem of your writemaster is the speedometer or what we call Laser Eye. This Laser Eye is damage but not totally can read only CDs but not DVDs, you can no longer burn a DVDs on it, i experience to that, only CDs can read and write on it. This time you buy a new DVD Writer to replace on it, or if warranty you can send it back to the Store you buy. I tell you it is still not working.. Just buy a new one. Good Luck!
1helpful
My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
well look for cds that are thicker and sturdier. some low cost CDRs are too thin and/or soft that they cant handle the heat generated by the cd drive.
CD / DVD ROM problem, can read cds or dvds that I create
Sounds like your need to install the codecs. Here's a good set of them: Download the full version and you might also want to check your dvd decoders,
http://www.free-codecs.com/download/K_lite_codec_pack.htm
3helpful
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
DVD drive reads DVDs but not CDs
2answers
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Acer (91.49C37.001) CD-ROM Drive Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
