The remote control has a "Game" button, which is how you select the external input. Since you don't have a remote you can select game mode via the front panel Menu button:
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the VOL(ume) ▲ button so that "PICTURE" is selected.
3) Select the feature you wish to adjust with the CH(annel) ▲ or ▼ button and adjust it with the VOL(ume) ▲ or ▼ button.
GAME MODE: Set to the most suitable position for TV
GAME. [+] : ON [ - ] : OFF
This will place your TV into Game mode and use the front panel video/audio jacks.
Here is a link to download the user guide:
http://www.sylvaniaconsumerelectronics.com/support/manual/index.aspx
Just enter your model number.
Please let me know if you have any questions.
Good Luck!
The previous "expert" sent me to the Owner's Manual. That was no help. That only shows how the unit is supposed to operate. Here is a restatement of the issue:
My Sylvania 6626LCT TV has a problem with one of the channels. When I enter the channel number (2-1) on the remote keypad the TV switches to that channel number but there is no signal. However, when I scroll to that same channel number (2-1) using the remote, it works fine (I get the channel 2-1 signal). I have two other digital TVs, neither of which exhibits this problem. And on the Sylvania all other channels work properly. It seems as though there is something stuck in the TV's memory. Is there a way to clear this out and start a fresh setup. I receive signals via broadcast. Rescanning all channels has no effect. I have tried first scanning with the antenna disconnected so no signals would be found, thinking this would clear everything out. I then reconnected the antenna and rescanned, but the problem is still there.
JustAskJoe,
I tried a different (Identical) remote and it didn't eliminate the problem. It was a used remote, but everything else seemed to work as expected so I'm satisfied that the problem is not in the remote. Any other suggestions or should I try another FixYa expert?
RichGun
