20 Most Recent Sylvania SRT2232S 32" TV Questions & Answers
I suspect you have simply switched to an unused input. If you use the original remote you can probably switch the input readily back to what you want.
Dave
Sylvania... | Answered on Jul 04, 2017
Main board fault. Check and replace it. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sylvania... | Answered on Oct 23, 2015
Why to ******* yourself with codes, installing etc. I order this Movie Software before a month, and I can tell it is awesome.
Take a look
Sylvania... | Answered on Apr 27, 2015
what channel did it need set on to work used to be 3
Sylvania... | Answered on Feb 23, 2015
Without a remote control; you can't do any further adjustments. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sylvania... | Answered on Oct 11, 2014
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Sylvania... | Answered on Mar 31, 2014
Horizontal scan output section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Sylvania... | Answered on Mar 22, 2014
As there is no 'Menu' button on the front panel of the TV, you should have a remote control, to adjust picture settings. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Sylvania... | Answered on Jan 19, 2014
0029,0022,0026,0281,0288,0280 are the common codes to be used with Sylvania brand TVs. If you wish to get more codes and other details check:
Sylvania... | Answered on Jan 09, 2014
The main power supply regulator board has the fault. The starting voltage might be faint. Contact any service technician. This is not a user repairable fault.
Sylvania... | Answered on Oct 07, 2013
Codes to check with Sylvania are: 2327 2304 2314. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sylvania... | Answered on Sep 05, 2013
Try these codes:
1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1077, 1088, 1116, 1130, 1132, 1134, 1161, 1183, 1189, 1196, 1353
These are the codes for Sylvania TVs.
Check this web page for instructions:
http://www.eliztech.com/remotes/rca-prog-v2.php
Sylvania... | Answered on Aug 28, 2013
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
Sylvania... | Answered on Aug 01, 2013
Refer its user manual for details. It has all. If you haven't it, download by this link.
Sylvania... | Answered on Feb 22, 2013
Sylvania SRT2232S 32" TV Logo
131 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
codes sylvania tv
  • Televison & Video
