20 Most Recent Sylvania LC370SL8 37 in. LCD Television Questions & Answers
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
Sylvania... | Answered on May 19, 2017
This is the way to enter any device using the rmc10 really big universal control.
1. Turn the device one that you want to program. (The tv, dvd, vcr, etc.)
2. Press and hold the CODE SEARCH button until the red light remains lit.
3. Press and hold the device you want to find (example TV, VCR etc.) Release it quickly. It wil blink once.
4. Continuly press the CH+ button until the device turns off. This may take a lot of time and many clicks.
5. Once the device turns off, press the MUTE button. This stores the code.
6. Press the ON/OFF button and the device should come on.
There you have it! Save this information so you will have it next time.
Sylvania... | Answered on Mar 02, 2017
There is a port on the TV rear called a "VAR audio out" use that. VAR stands for variable.
Sylvania... | Answered on Nov 03, 2016
From the bottom there should be a couple of screws to hold the base on. If they are not there then you need to remove the concealment panel at the base where the stand goes in. Once that is off you will see 3 or 4 screws holding it on.
Sylvania... | Answered on Dec 12, 2015
I also have the same Sonyo tv I just i just followed the instur as listed. I JUST KEPT PUSHING THE CH+ over 6times and my tv shut off... Btw Sentry Big Remote works Wonderful
Sylvania... | Answered on Sep 23, 2014
Was it rush hour?? LOL
Sylvania... | Answered on Jun 10, 2014
Some remotes will not work with some units. If the codes will not work, and the remote find function does not work, purchase a new universal remote that will take more codes for more units. They are about 25 to 150 bucks and should handle both units. Otherwise you have your excuse for a newer TV.
Sylvania... | Answered on Nov 16, 2013
Is it a PC with TV? If yes, try to download the codec software appropriate for your operating system. Let me know it is.
Sylvania... | Answered on Sep 19, 2013
You may be able to repair the board instead of buying a replacement board. If you are up to a little soldering it may save you a good bit of money for the repair. If you are interested just take a few pictures of the boards and email them to us at tech@ccl-la.com We will check them out and give you some pointers on what to do. Most power supply issues with the blinking power lights are caused by blow capacitors on the power board. These are fairly easy to replace and the replacements are less than $20 usually. To get an idea what capacitors are and what will need to be do to repair you unit check out our pages at :http://www.ccl-la.com/blog/index.php/capacitors/ You may want to look over the repair guides for other units we have posted too. If you need parts we can also supply them for you. If you have any additional questions just contact us at: tech@ccl-la.com
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sylvania... | Answered on Aug 11, 2013
How do we turn on the speakers for Model LD190EMI, Serial DSIA1018179728 Emerson Television Receiver
Sylvania... | Answered on Jul 19, 2013
A bad inverter board will produce this exact symptom. They are commonly available on EBay for about $60 USD The part number is. 1FSA10164 It should take about 20 minutes to replace without great difficulty.
If you or someone you know is good at component level PC Board repair this issue is almost always a bad transformer. All it takes is for one of the 6 transformers to have and open winding and the TV will start breifly and then shut down because it has a comparator circuit that monitors all 6 outputs to the lamps. If one of the outputs is missing the TV goes into "Protection Mode" and shuts itself down. The individual transformers can be checked by using a digital multimeter and checking resistance of the windings, should be about 2.7 MOhm, if one reads Zero Ohms, replace it. (You can check the resisitance while they are soldered to the board. Power down the set and let it sit for a bit them remove the connectors and the 6 mounting screws to pull the card.) The transformers are available for $4.95 from Electronica-usa.com the part number is LTZ2PCOMS008 (and yes the shipping costs more than the part, but still cheaper than tossing the TV)
Sylvania... | Answered on Jun 18, 2013
Take the Inverter Board out and check for Open windings on the 6 Transformers along the edge of the board. When you find one open, get the number off of the Transformer, Google it, buy one and replace the bad transformer. I was given one of these TV's and fixed it for $11. It's not rocket science, if you can use a DMM and a soldering Iron, you can fix this.
Sylvania... | Answered on Dec 18, 2012
Sylvania LC370SL8 37 in. LCD Television Logo
105 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
need remote code sylvania lc195slx att
  • Televison & Video
