The installation software for most computer peripherals can usually be found on the manufacturer's website. I have included the link to the website below. Click on the blue text under Recommended Downloads that starts with "Complete driver and software...". Please note that this looks to be for a Windows system only, not a Mac, and that the windows operating system needs to be 32-bit and not 64-bit. Once you click on the link a new window will come up. Scroll to the bottom of the page and click "Download". The file cjr1200EN.exe should begin downloading. You can either save the resulting .exe file to your computer or just run it. For best results, your printer should not be connected to your computer until after you have installed the software package.
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X1270&page=product&frompage=null#4
Hello there,
Directly from the Lexmark website, here is the Driver Utility link. It is compatible with all Operating Systems.
1. Disconnect your printer from your computer
2. Download driver utility
3. Once download is finished double click the installation file
4. Accept to any agreements/prompts and do an automatic install into default system folders
5. If the Driver Utility asks for your model number, find Lexmark X1270 in the list of InkJet printers
6. Once the Driver Utility tells you to connect your printer to your computer do so
7. Follow any remaining instruction to finalize the installation
I hope I have helped you solve your problem. If I haven't I will instruct you to another solution, please don't vote until you are satisfied and sure my solution didn't help at all. Thanks in advance!
You should be able to download the appropriate drivers by clicking this link:
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X1270&focusedTab=DOWNLOADS#1
Make sure to choose the correct Operating System from the pull-down menu then click FILTER
I hope this helps.
Best of luck!!
Please find the link below to download the drivers:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_AU&locale=en&productCode=LEXMARK_X1270&page=product&frompage=null#1
Thank you for using fixya.
You can download the driver from Lexmark's website. I have provided you with the link. Just click on it. Once you're there, scroll down and look for Recommended Downloads and click on the blue link that says "Complete drivers and software for setting up, configuring, and using your device with Windows 32-bit"
Here's the link to the site:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X1270&page=product&frompage=null#2
CARLO
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link
and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
