Lexmark X1270 All-In-One InkJet Printer Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install a 2250 lexmark printer software
How can I install the 2250 lexmark inorder to print normally from my computer
Geraldine Watts
Level 2:
Sergeant:
  • Expert 390 Answers
  • Posted on Jul 31, 2008
Geraldine Watts
Expert
Level 2:
Sergeant:
Answers
390
Questions
0
Helped
115526
Points
570
You have not stated enough. Was it already installed and stopped printing? Is this a first install, what printing issues were you having, or any errors it tells you please.
I have my lexmark multifonction ,i install it normally in windows 7 64 bit, i can print normally but i can not scan document please i need your help when i scan a document i receive this message unable to...
Please download and install the scan drivers on your computer from support.lexmark.com website. Make sure to properly filter the operating system and then click on the downloads tab, you may select the link under drivers "Complete drivers and software for setting up, configuring, and using your device" when you install you may customize and select the local scan drivers.
For further assistance, please contact Lexmark Technical Support.
I have a lexmark x63 and everytime i try to print something it says the device is busy try again later. i click on the printing icon that pops up in the bottom right hand corner of my screen and there is...
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site, www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
Lexmark x 2250 not communicating with computer, power light is on but would not turn off as well
1. Check the USB cable connection; replug in the USB cable to printer and computer;
2. Go to Start\Control Panel\Printers\right click on lexmark printer icon, go to Properties\Advanced\ Print processor\ change to NT EMF 1.008
It will work.
Printer not printing
plz give me laxmark X 2250 printer driver
Printer will not print even though it is attached to the computer.lexmark x1240
Most likely you don't have drivers installed on your computer for the printer. If you have the CD that came with your printer, the drivers and software should be in there. If not, you can look up drivers on Lexmark's website or somewhere else on the internet and download the software/drivers and install it on your computer. After installing the drivers, reboot if necessary and try printing something. It should be printing by then.
2answers
Drivers for lexmark 2250 for fax facility
lexmark site http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:436:0:0
I am not sure if this is software driven, or this is a PC to Fax setup?
LEXMARK P6350 All-In-One
Did you ensure you connected the usb cable and printer in order of the disc requesting you to do so.
Have you been to Lexmark site?
Have you enabled the printer in Printer settings as a default printer? It should normally do so when installed, but worth checking if you have other printing software on your comp
Regards Faggly
2answers
Can't get my printer to print
Hello lilltlellulu2,
This is Enday, to solve your problem, try to check if you have installed the ink cartridges properly... If you have installed the software for the printer ,you must restart your system unit inorder to take effect on what changes you made..so as ther hardware to work.
Now, after restarting, click on the control panel, then printers..as you can see your printer installed,,right click on the printer icon>properties>print test page...
Just see if its working this time...
Thank you... and Good day...
Enday
1helpful
2answers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
