Hey i need help too when ever i try to do it it says a connection has occured.
a connection to the point
could not be established.
check the security settings
for the network and try
again. this is for when i try to conect my wireless on my psp but it always says a connection has occurred.a connection to the access point cannot be established.check the security settings for the network and try again. but this never works can you please give me some help
The reason behind this is very simple, that is you're connecting to a very weak network. I believe when you're connecting your psp to the wireless network, you get to select the network that you wish to connect to. Points to take note when you select any network.
1. % indicated is recommended to be 80% and above to get a stable connection.very often, connection cannot be established because reception has been really bad, and weak.
y
2. Wi-fi switch must be switched on when wireless is attempted.
3. if security is WEP, a network name and password is required.
if you've done the above and it still doesnt work, your wifi board could be faulty.
Have you tried setting it up manually? Coz if you are connecting to a private connection, i believe you need to set it up manually, with all the passwords needed (for example the WAP keys, etc...)
i have the same promblem it started when i format memory stick and then i went to restore default settings and nothing happend and now got this wierd **** comeing out saying check network this and that
my problem is the same as what is being described
