2003 Buick Rendezvous Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buying used truck owners says it needs lifter valves what am i looking at in cost
Anonymous
Level 3:
Genius:
  • Master 1,165 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1165
Questions
0
Helped
383458
Points
3606
If it needs lifters and valves, I would suspect the rest of the engine is in the same shape. My guess is you would be looking at a couple thousand dollars to rebuild the engine.
Anonymous
Level 3:
  • Buick Master 6,982 Answers
Anonymous
Buick Master
Level 3:
Answers
6982
Questions
0
Helped
2649899
Points
22782
In order to replace the valve lifters, the rocker arm covers need to be removed, Rocker arms and push rods as well as intake manifold. if you have an overhead cam engine it's a bit different but should be about the same amount of labor hours. Price varies with each shop and parts cost depends a lot on exactly what is found after the engine is apart.
Unless you have a competent technician look at and verify that the lifters are the only problem, you may be getting into something very costly. Lifters can fail in two ways: The internal plungers can get stuck or internal clearance may cause excessive pressure bleed off causing them to get noisy. Or, the camshaft (the lifters ride on that) may become worn and cause excessive clearance that the plunger inside the lifter cannot compensate for. That requires a cam replacement which is expensive.
One other item: Good lifters can become noisy if the engine oil pressure is low. The primary cause of low oil pressure is worn engine bearings. In that case, you'd need a complete engine rebuild or replacement.
An experienced tech can do a pressure test using a mechanical pressure gauge to verify the actual oil pressure and he can advise you on what he thinks about that and the overall condition of the car.
Personally, I would not buy it unless it's in exceptionally great condition and I had the time and $ to invest in doing the repairs. There are lots of good vehicles out there and buying one with obvious problems is often the beginning of something you don't want to do (like cleaning out your bank account).
Anonymous
Level 3:
President:
  • Master 1,702 Answers
Anonymous
Master
Level 3:
President:
Answers
1702
Questions
0
Helped
767551
Points
5420
You have to remove the cylinder heads to replace the lifters, depending on were you live $800- $1500
Need valve clearance when setting the tappeds on a 2005 nissan 1400 bakkie
is this in Africa TAppets ,are you sure it has this< and is HLA?
what engine is there exactly?, (step 1 to work any engine is. this.
gas/petrol of diesel? engine size. like, 3.0L? V6?
wiki
The 1400 Bakkie was assembled by Nissan in Rosslyn, South Africa (Nissan)
1.4L engine a very small pickup truck and tiny obscure engine
that wiki fails to identify.
buy the manual for NISSAN.
it is not a diesel ,and this list is all 1.4L listed by maker,1.4L and in year range.
GA14DE DOHC, 2 CAMS? AND ROCKERS? 12VVALVES
The GA14DE does not have hydraulic lifters, so special shims are used to adjust the valve clearance.
CGA3DE DOHC, 1,4K Sold as but is 1.348L
data super hard to source on the engine.
one photo shows head cams over valve stems, no tappets at all
see photo, I see bucket lifter there, so are shims.
CR14DE, with vvt
The Nissan CR14DE motor does not have hydraulic lifters, so special valve lifters are used to adjust the valve clearance.
so knowing this engine fact and the exact one makes this more easy
lacking manual or engine name, i'd look first.
CDA3DE, FOR SALE, SEE THE BUCKETS , I DO.
2answers
I've got a 94 Honda prelude one of the lifters is knocking and I have oil in the spark plugs I need to know how much it would cost and what I need to do
First remove the valve cover to see if the camshaft is damaged. If not, maybe you can get away with changing the lifter. Remove the camshaft and find the bad lifter. It will be worn on the surface that the cam faces. The valve spring may also be broken. The oil is likely coming down the valve guide. Remove the valve spring and check to see how loose the valve is in the guide. If loose, you'll need to pull the head and have the valve guide replaced. Not sure if that is going to be worth tne cost.
I have a1968 chevelle with a 396 engine i recently changed the oil in it and went to syntheced oil and my lifters seem realy loud whould this be the problem
Since you replaced a valve spring you know how.. I would replace them all since one broke.. I think this car is a hydrolic lifter.. you may not have adjusted them correctky.. possibly buy new lifters, and springts from Summit racing or Jegs.. and replace them all .. this is not a very costly repair if you are doing the labor. When you have it apart look at the top of the valve that hits the rocker are.. you are looking for wear and cracks.. Look at each rocker arm looking for the same.. Please post a comment and let us know what you find..
1993 chrysler sebring lifter replacement cost
depends on where you bring it. if a lifter broke then your valve could be damaged to and then you need to redo head and gaskets. if no damage your looking at around 500 avg
2helpful
2answers
How much does it cost to fix 1998 ford expedition valve lifters
CANT GIVE EXACT PRICE WHEN YOU REPLACE LIFTERS DOING BOTH SIDES ABOUT 6 HOUR JOB IN LABOR DEALERSHIP COST RANGE CLOSE TO $2000.00 OR MORE DEPENDS IF TIMING CHAINS HAS TO BE REPLACED AND CAMSHAFTS WORN OUT.
2helpful
2answers
One of 6 lifters is making a "ticking noise", I have changed oil and filter and now use synthetic 10w30 oil w/1 qt. of Lucas additive. Still have problem and sometimes it stops and then returns.
You have a lifter noise if you leave it at idle does it return and gets louder? and when you rev it up does it go away? If it does you are looking at a failed oil pump. Look at the front main pulley is it wobbly? The reason I ask is the 300 has a high oil pump failure pattern when it fails it takes out the timing chain these you need to beaware of
8helpful
3answers
What can cause a knocking at the right hand side valve cover
Hi , usually a knocking / pinging from the valve cover indicates a lifter tapping. Could be worn out or just worn. Do you change your oil every 3000 with high quality oil? (I always have used valvoline standard with outstanding results) Dirty oil and filter and or incorect weight oil and or using synthetic oil in older cars can result in lifters tapping. If your oil is under 2000 miles since last change and you used a high quality oil (watch who changes your oil, some places use inferior oil because its cheaper) you can buy a pint of oil treatment formula to quiet noisy lifters to coat the lifter and quiet it down. It is a sign of engine wear, but one lifter tapping a bit wont really hurt your engine mechanically. If they all get noisy, time for a valve job. Root cause is wear due to insufficient lubrication. The lifters on newer cars are all hydraulic and they self adjust. No manual adjustment is possible. Bottom line: keep your oil changed regularly using a high quality non-synthetic oil for your 1999 vehicle.
Please rate this answer! Thanks, Mike
1helpful
My motor ticks when it gets to runnin tempature could that be a valve or lifter
YEP BUT NOT REALLY.DO THIS LITTLE TEST.CHANGE OIL + OIL FILTER.BUY A BOTTLE OF MARVEL MYSTERY OIL FOR NOISEY VALVE LIFTERS.IF THIS DONT STOP THE LIFTER NOISE.LIFTERS ARE WORN.ALSO MAKE SURE YOU ARE USING 5W - 30 OR 10W - 30 MOTOR OIL.
3answers
What is a lister?
LIFTERS. Have a mechanic look at it BEFORE you buy it, you dont want to buy a problem child. there may be oil pressure problems, big $$$
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
