2000 Toyota Camry Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toyota camry 2000 xle 4 cyl keeps over heating after ive change the oil and water pumps, put in a new radiator and replace the thermostat and it keeps over heating when driving for a long time
githinji wahome
Level 2:
Habit-Forming:
New Friend:
  • Expert 72 Answers
  • Posted on Feb 14, 2011
githinji  wahome
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
72
Questions
0
Helped
20806
Points
165
Before you go to the big things, have you bled the system properly after the install? This could cause over heating and can be checked if the return hose on the radiator is cold and other is hot.
Overheating could also be because of a head gasket so please have that pressure tested also.
Happy Motoring
G
Anonymous
Level 3:
  • Master 878 Answers
Anonymous
Master
Level 3:
Answers
878
Questions
Helped
191701
Points
2195
Check oil make sure is not milky ,is it bubbling in reservoir cause the only thing that can cause it is a blown head gaskek
How to replace a fog light bulb on a 2004 Toyota Camry
Video Description
The video above shows how to change the fog light bulb in your 2004 Toyota Camry. Not all models have fog lights - for many Toyotas, it depends on your trim level (XLE) or whether the fog light option was ordered when your Camry was manufactured. Fog lights are typically in the front bumper, below the headlight cluster and are helpful in poor visibility. If one fog light is burnt out on your Camry, we recommend changing both bulbs because the working bulb will be dimmer than the one you replaced and will likely burn out soon anyway.
When you change the foglight on your Camry, be careful not touch the glass part of the bulb with your fingers which causes the bulb to burn out earlier.
Other videos you might find helpful
  • Replace reverse light White light when you back up - yup, they burn out and you can replace them with bright LEDs
    2003 Toyota Camry XLE 3.0L V6
  • How to add transmission fluid If your transmission is running low on fluid, be sure to add some - find out how to do this here!
    2006 Toyota Camry LE 2.4L 4 Cyl.
  • Complete oil & filter change Sure you can take it in for a $19 lube, but are you OK with a stripped oil pan and cheap parts in return?
  • Fix leaky hoses The best way to fix leaking hoses is to replace them, but if you don't have time, a stop leak product might work for you
  • Set the clock to the correct time Is the clock in your car ahead or behind? Learn how to set it here!
  • Oil level check Cars burn, leak and otherwise dispense of their oil. Check your level frequently and top up when necessary
  • See all videos for the 2003 Toyota Camry
Toyota Camry 1993 4 cyl water pump failing, have removed thermostat, considering Electric inline pump as replacement as option ? Please advise me of pro's and con's.
i owned the 1995 4 cyl wide body camry till the cooling system failed in heavy traffic and over heat stripped out the head bolt threads in the block
the toyota camry engine designation is a 5S-FE
water pump is driven by timing belt
behind timing belt covers
they have to be removed to get to the water pump
normally timing belt, seals ,tension er pully and water pump are replaced at the same time ..comes in a kit
i dont have the 5S-FE cooling system hot under pressure specs
so I cant answer which inline electric pump pressure is required to work on the 5S-FE
engine repair manual free download pdf
5S-FE 431 pages
http://www.turboninjas.com/camry/eg1.pdf
ENGINE MECHANICAL to page 144
EMISSION CONTROL SYSTEMS
MFI/SFI SYSTEM page 164
COOLING SYSTEM page 238
LUBRICATION SYSTEM page 268
DIAGNOSIS SYSTEM page 296
CIRCUIT INSPECTION page 336
water pump as a part
timing belt water pump kit
water pump
,location on the engine with timing covers removed
e7622159-98af-4a83-8989-bd6dd48bcde3.jpg26279563-dp42dlzfhn4dbdhi1rc14q4e-1-2.jpg26279563-dp42dlzfhn4dbdhi1rc14q4e-1-3.jpg
I have a 1994 Toyota Camry XLE 4 cylinder. its been having problems overheating so I was just putting antifreeze and water in it for about a month. I replaced the coolant sensor and the thermostat, still...
Sounds like a leaking head gasket. The head gasket can allow coolant to leak into the cylinders, and compression to leak into the cooling system.
2answers
2000 dodge durango cooling issue: I HAVE THE 5.2L 2WD. I have replaced the water pump, thermostat 3 times, hoses, fan clutch. To begin with ive had it tested at three places no one can figure out why...
Ihave a 2000 Dodge Durango i have put a new radiator and the gaskets came back good um i replaced the coolen fan also the thermostate and tested it it it came back good when i run it its fine but when i am in line its hot when i drive it cools down........
1helpful
Need to know how hard is it to take water pump off, need break down diagram.
Need to know which model sedan you have, CE, LE, XLE, and which motor you have 2.2 4 cyl or 3.0 V6, also email address to send diagram/instructions to replace your water pump, no they are pretty easy to replace.
2helpful
The water on my car keeps heating up alot and it goes into the engine coolant resevoir leaving the rediator dry
You need to replace the radiator pressure cap. I would also replace thermostat, drain and flush radiator to start. If it continues the water pump may be not pumping water. If the thermostat is stuck closed it wont allow water to cycle through the engine causing it to boil and the pressure cap is not holding the pressure allowing it to flow to the reservoir. So first change the thermostat and the radiator pressure cap.
2answers
EXHAUST LEAK INTO COOLING SYSTEM?
Sounds like you have a partially plugged radiator. Try flushing it out and see if the problem changes at all. When flushing, force water to flow backwards from the normal flow direction this usually frees up some of the debris built up on the core passage ends. If you must, remove the radiator to do this. Depending on accessability, I usually just tape up the end of a garden hose and put it into the outlet on the radiator (but have gotten as radical as using a pool pump and lime out to do this job!
Is there any coolant in the engine oil or trans?
2answers
I have a 1988 4 door Toyota Camry. It has the Toyota 2000 16 Valve Engine with E.F.I.. The problem Im having is that it keeps overheating into the red within 30 minutes of driving. If you put the heat on...
Had a similar problem with my camry wagon, was going through thermostats every 6 months... dunno why. Best way to figure it out is just to buy a new thermostat and replace that first. It's really easy to do, and a new thermo will only run ya about 20 bucks.
best of luck.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
