Please could you conirm if i have conntected the boxes correctly.
(A) I have the YELLOW cable connected from the computer Hardrive to the D-link box in the Lan 2
(b) I have the BLUE cable connected from the Modem box to the D-Link box in the Internet slot.
Many thanks and kind regards, pinky
Be sure the cable is connected correctly red is in the one labeled R and the white is in the L and that the yellow is in the yellow OR green. Then make sure the TV source is set to component/AV. Check the display settings on the PC to be sure it is set for that correct output. Let me know if you need more help.
Usually old motherboard requires a PS2/older type keyboard to be ready connected when booting.. and I think the hardrive is already faulty.. try replace the hardrive IDE cable..
If you have a cable box you need to connect this box to the TV. Find the OUT plug on the cable box and connect it to the corresponding IN plug on the TV. You can use several different connections to do this however they need to be consistent. For example, if the cables on your cable box are Red, White, and Yellow then the connections on your TV should also be Red, White, Yellow. These connections are color coded so you can match them up appropriately. After you have connected the cable box to the TV, you simply need to cycle to the correct input channel. To do this find the Input or Video Source button on your TV remote. Cycle through the inputs until you see/hear a signal.
If you do not have a cable box, simply connect the Coaxial cable to the back of the TV. This cable should screw securely onto the TV. Once you have done that, use the TV remote to change the channels.
If you have any other problems please contact me :)
Hi I am a silver surfer but this is how I got it working First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
