Sharp R-630D Microwave Oven Logo
Posted on Feb 02, 2011
Ho heating and noise - Sharp R-630D Microwave Oven
3helpful
2answers
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
My GE GSS22JERF BB refrigerator, is making a clicking noise. This noise is coming from the back of the fridge. Can you tell me the problem?
The clicking noise will be the radiator expanding and contracting due to the heat exchanger removing the heat from the food in the fridge.
Everything on the microwave seems to be working properly, but it is not heating. The power level button says ho -20??? It lost heating abilities during cooking. Thanks!!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2helpful
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
1helpful
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
1helpful
No heat. light ok, noise hasn't changed. I heard a pop
It's most likely the relay for the magnetron malfunctioning. It'll need professional service.
1helpful
2answers
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Not heating
If the maggie went it's very plasible that it took out the Cap and/or HV diode with it.
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
