Sharp R-230 800 Watts Microwave Oven
Problems with Sharp R-230 800 Watts Microwave Oven?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Sharp R-230 800 Watts Microwave Oven RSS Feed
View More Results for Sharp R-230 800 Watts Microwave Oven
Questions and Unsolved Support Problems
Unsolved Problems for Sharp R-230 800 Watts Microwave Oven RSS Feed
Answer
my microwave works but the timer digits can not be seen clearly
Answer
i have been given a sharp microwave r-269slm but inside on the right something like a bit of... (More)
Answer
I'm not able to use the compu defrost on my sharp carousel R-508 AK microwave. Does someone have the... (More)
Answer
I get an EE error when i try to defrost with my "sharp carousel microwave"
Answer
microwave stop working because of running for 45 min, by accident instead of setting up the timer.... (More)
Find a Manual
Sharp R-230 800 Watts Microwave Oven Manuals & Guides
WikiManual
(Post a New Chapter)
How to Clean a Microwave
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if... by wikihow
Upload Manuals
Tips & How To Guides for the Sharp R-230 800 Watts Microwave Oven
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Cleaning a microwave secret
When you want to clean your microwave, boil a container of water in it for a couple minutes. And the food and grime will wipe off easy. written by baugh55grfmj
Microwave Oven Door Handle Replacement
Door handle broken? Don't replace the entire door, or the entire microwave oven. As long as the the door facing is still intact, the door handle can... written by jsrock516
GRANNY?S NUKE NOTES
Twist the timer knob or push the button and electricity from the wall outlet travels through the power cord and enters the microwave oven through a... written by TheMobilian
This is a test
This is a test test test written by joe123r
Replacing a Turntable Motor on a Microwave
The following advice is for MOST microwave ovens (including over-the-range models). This is a fairly simple repair that can be accomplished without... written by jsrock516
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case... written by ptishkevich
Microwave works normally but does not heat.
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron. The... written by ginko
Micorwave ovens - and where's the heat?
A microwave not heating up is caused by one or more of the following - 1) Failed controller board (unlikely if you are getting a clock readout and... written by MrMark52
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sharp R-230 800 Watts Microwave Oven
Nationwide | 866-240-3413 | Website
When onsite service is not an option you can count on ... Read More
Nationwide | 423-303-3785 | Website
Microwave, blender, mixer parts delivered ove... Read More
Nationwide | 718-584-3449 | Website
Authorized Service center for Saeco, Gaggia, Spi... Read More
Nationwide | | Website
Owner's Manuals and dough kneading paddles for jus... Read More
Ratings for the
Find a Warranty
Specifications for Sharp R-230 800 Watts Microwave Oven
Key Features
Microwave Type
Countertop
Cooking Power
800 Watts
Capacity
.8 cu. ft.
Convection Cook
Without Convection Cook
Power Levels
11
Other Features
Turntable
Yes
Turntable Diameter (display)
11.63 Inches
Dimensions
Exterior Depth
14.62 in.
Exterior Height
11.37 in.
Exterior Width
18.12 in.
Safety Features
Safety Standards
Federal Communications Commission (FCC) · Department of Health and Human Services (DHHS) · Underwriters Laboratory (UL)
Child Lockout
Yes
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Describe your problem:
Top Microwave Oven Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
