20 Most Recent
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Questions & Answers
Where is the fuse located on a kitchaid microwave
It is located behind the key panel. UNPLUG THE UNIT FIRST.
Remove top grill (2 sinked screws on top)
Now remove the single screw on top of the key panel. Barefully slide out the keypad up and out. The smart people of kitchenaid put the dang fuse jammed between the fan housing and the right wall. Remove the entire bottom plate that holds the lights and such... I think 8 screws. Now remove 2 screws that hold down the fan housing. Now you going to have to use a screw driver and some wiggling to move the plastic housing out of the way enough to pop and slide out the fuse and replace. To test you can use a continuity tester and place it between the fuse. There is nothing visible on this fuse (250Volt 20A fuse Fast Acting I think) e.g. you can't see that the fuse is broken or not. Make sure no wires are pinched while putting it all back.
Microwave starts by itself - NO JOKE
You have a shorting
membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
If not, please reply back with your brand and model number so we can help you better.
In many brands there is a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
If you would like to
have us do this repair for you, we do that for $39.95 plus part costs.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
How to resolve the F6
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair.
Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
How do i replace door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The part number for the model number you provided varies depending on color, so make sure you order the correct one for your oven. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
Kitchen Aid (KA) Over stove Micro - vent grill plastic brackets
My grill has also fallen off twice. It usually results in the tabs breaking off. My solution has been to add tiny (1/2" x 1") shims in the slots where the tabs have broken. Look carefully. There are two tiny channels. I wedged the wood in and then reattached the grill using sheet metal screws in the same screw holes. It won't come down again.
In three years since doing the kitchen with all KA appliances we have replaced the grill once. We had the stove removed and replaced by the appliance company at no charge after 4 months. We had our ice maker replaced out of warranty. I would never recommend KA appliances to anyone. The quality is absolutely terrible.
Door handle replacement
your better to dismount the door first
you may need to remove the top case
{no power empty the glass out etc incase you need to tip it over}
sometimes you need to remove the whole top panel
either look for the expoded view for it also
and take lots of pictures first and as you go
go for it you can do it
its easy
i recon 8 screws max for the top of the case
and 4 screws for the top hinge
and then lift off the front
four screw to take off the actual front
and 2 screws for the handle
,,,, thats 14 screws in and out
