20 Most Recent Maytag MMV4205 Microwave Oven Questions & Answers
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Maytag MMV4205 ... | Answered on Dec 31, 2017
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Maytag MMV4205 ... | Answered on Mar 19, 2016
Could be a damaged or defective door latch
Maytag MMV4205 ... | Answered on Jul 17, 2015
try e spares on the internet
Maytag MMV4205 ... | Answered on Feb 19, 2014
I would open it up and look at the connections to see if any can be replaced. Look for any darkened or burned looking connectors related to the display panel. Hopefully you won't need to replace the display panel circuit board but if you do. I would look for the cheapest replacement starting with ebay parts, and search engines for that specific part. Sometimes there are microwaves of different models with the same parts too!
Maytag MMV4205 ... | Answered on Nov 07, 2013
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
Please post a new help request with that and more detailed symptoms, such as when it occurs.
Maytag MMV4205 ... | Answered on Apr 16, 2013
check to see if the power from the wall socket is there. Plug in a lamp or somthing. If it works, then the microwave burned out an internal fuse, or curcuit board.
Maytag MMV4205 ... | Answered on Oct 08, 2012
If the oven is dead - no display, no beeps when you press a pad on the keypad, and no inside light when you open the door - then I would suggest that you very the outlet is okay under load.
A hair dryer or toaster are the best ways the average DIYer can test the outlet under load.
If that's good, then your microwave may be dead due to a blown fuse, magnetron thermostat, or oven cavity thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse and magnetron thermostat are good, then you will have to take the oven down from the wall to get to and test the oven thermostat.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're
Maytag MMV4205 ... | Answered on Sep 06, 2012
You can find handy exploded views and order parts by model number here.
Maytag MMV4205 ... | Answered on May 31, 2012
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Maytag MMV4205 ... | Answered on Apr 23, 2012
Maytag MMV4205  Microwave Oven Logo
116 questions posted
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
door shut all way inside light stays
  • Microwave Ovens
