I have a HP Pavillion Slimline on Home Vista, I keep getting a pop up that says open file-
security warning unknown publisher and it is asking me to run file. How do i stop it from popping up. 9 popped up as i was typing this. HELP
Chabs Liverpool
1.Requires it to be run in Windows XP Compatibility mode.
2.Ftm.exe is not signed aka doesn't have a publisher prompting user account controls in Windows 8. (Security issue)
Compatibility mode for FTM 2012 in Windows 8:
1.From desktop, right mouse click on FTM Icon on the taskbar
2.Hover over "Family Tree Maker 2012" and right mouse click again to get Properties
3.Click on Properties
4.Choose Compatibility tab
5.Under "Compatibility mode", check box "Run this program in compatibility mode for: Windows XP (Service Pack 3)" Side note: after utilizing "Run compatibility troubleshooter" this is the resolution I got.
6.Click okay and test to see if program opens properly.
Note: due to the ftm.exe not having publisher info, each time I open file, I get security prompt to allow unknown publisher to make changes to my computer. Family Tree Maker must address this issue.
The HP Mini laptop comes with either the Windows 7 or Windows Vista operating system. You can restore the HP Mini to its factory settings using the laptop's recovery partition. Restoring the HP Mini to its original factory settings will get rid of hard to eliminate viruses on the laptop's hard drive. A factory restoration is also a good way to get rid of older files still stored on the computer that you no longer need and start with a clean slate.
Windows Vista Click "Start" in the lower-left corner of your HP Mini Windows Vista home screen, then type "Recovery" into the Search box at the bottom of the Start menu. Click "Recovery Manager" in the list of options that appears above the Search box. The HP Recovery Manager will open. Click "Advanced Options" and then "System Recovery." Click "Next." Your HP Mini will restart. The HP Recovery Manager will open up automatically after the restart is complete. Click "System Recovery," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process begins. This could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista. Windows 7 Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager." Click "Recovery Manager" again to open the HP Recovery Manager program. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista.
i hv purchsed HP Pavilion tx1000 notebook pc. it was getinig vy heat due to this region pc was getting shut down. i hv given it to my near by service center. but still it is not working properly. its web cam as (HP pavilion Webcam Driver for Vista v061.001.0005- chicony) driver is also not loaded properly. when opens with net it gives error.
pls help me wht to do?
