I need to know the brands and models of your ram's, take all the text from the old chips and write them here, also from the new chips, and write them here.
I'll know more once you've done that.
As for the beeping, remove all the ram from the machine, and power on, it should complain, turn off, unplug, install ONE of the old memories back in and try starting up, what happens?
OK ..this is an issue with the ram memory ..and the first thing to do is to remove the BIOS battery for a few seconds and after that insert it back ...Also check again the ram modules and press them in the slot firmly ..cause usually this is happening when one is not recognized or faulty ..an it can be cause you damaged it during the installing ..or cause it is not proper inserted..
Like I said ..after checking all this..remove the BIOS battery ..place it back ..and restart ..This will erase the cmos settings ..and make it recognize the new memory ...if it is functional ..
If all OK ..it will ask to press F1 to get into bios settings and set the time and the date ..but it is easier to just ..get in there and press F10 to save them all like they are ..and deal with the settings in windows..
If this will not make it work ..remove the memory modules one at the time ..and try to boot with one single one ...and this way you will identify the one that makes problems ..
If non of them will boot the computer ..it means that you have bought a wrong frequency ..and it is not supported...In this case either change it ..or update bios ..to make the new frequency supported..
I mean usually older computers supports for DDR@ for example up to 533 ...but all you find on the market these days for ddr2 are from 800 up ..and things like that ..
You should folow the manual when upgrade this thing s..
BUT if it is Ddr1 it should not be a problem cause they usually all 3 frequencies work in the slot ..
This problem occurs because of frequency incompatible between RAM.
For that you need to install same frequency RAM .
Also try with only 1 RAM make sure both RAM is working fine.
Try different RAM slot if 1slot or RAM is not working then also this problem occurs.
Let me know if you need further assistance.
Thanks for using FixYa.
For RESET bios settings to defaults.
Pull cmos cell from motherboard for 10 minutes then all settings defaults.
Open processor and it's fan make sure motherboard is not ground with cabinet.
Reinstall pci or vga card if any then check.
I tried putting the old RAM chips back in to teh slots, I still see the same problem
I tried putting the old RAM chips back in to the slots, I still see the same problem
Where can I find CMOS cell? How does it look like? Is that a plug-and-play component that I can pull off easily and put it back?
I have replaced 2x256 RAM chips by 2x512 chips in my HP Pavilion 752n running Windows XP SP2. My computer does not boot after the installation. Weirdly enough I get 6 beeps when I turn on my desktop, and nothing happens after that except my computer fan runs endlessly. Are there any know known issues or suggestions while replacing RAM chips? Can someone advise?
Can I chat with you?
I can not locate BIOS Battery. How does it look?
