Does it overflow or does the water drain right back out? Does it do it when the unit is unplugged? Does it do it when you turn it off manually with the timer knob? What is your model number?Does it overflow or does the water drain right back out? Does it do it when the unit is unplugged? Does it do it when you turn it off manually with the timer knob? What is your model number?
You can't post conmments that contain an email address.
Check that your battery is charging. If your car stalls after one stop then likely you don't have charge in your electrical system. Could be a bad alternator, battery, faulty wiring, etc.
YOU PROBLEY HAVE A WATER PUMP IMPLLER THAT IS BROKEN THEY HAVE PLASTIC IMPELLERS THAT AFTER TIME COME LOOSE FROM SHAFT AND WATER DONT MOVE CAUSING WATE TO BACK UP OU OF WATER BOTTLE ALSO CHECK TO SEE IF FAS COM ON WITH AC ON THE FUSE IS IN THE FUSE BLOCK ON TOP OF BATTERY ITS THE THIRD FUSE 30 AMP CLOSEST TO NGATIVE BATTERY TERNMAL
It sounds like its overheating. Try cleaning out the radiator fins using a high pressure air-line. Be careful not to damage the fins. Also check the radiator is full of water and anti-freeze.
I guess you will have to wate till you get home but if you have the program on the computer then it shald still work. you can look in the help section "solutions",.
STOP WATING MONEY,STICK TO THE SIMPLE,PUT CAR ON SCANNER,LOOK AT THE O2 SENSORS,LOOK AT TEMP,LOOK AT AIR TEMP,ALLTHESE SIMPLE THINGS WILL SAVE YOU MONEY
hI try
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off. 2 - hold stop/reset ,hold ON/OFF 3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF 4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly 5 - then push power twice, quickly 6 - power off and power on.
All Best: Pineworks
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
There is no replacement absorber for your machine. During warranty Canon would replace the whole printer, after warranty, you toss it and buy a new printer.
