SOURCE: Gorenje WA1541 Washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
SOURCE: Whirlpool washer does not spin
this machine does not have a belt it has a direct drive coupling, the coupling is in between the motor and the transmission it is what makes the machine spin part number is 285753a aboout 10-12 dollars give or take
SOURCE: my kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
SOURCE: problem with my washing machine gorenje wa483
the filter is there for a reason,don't jury rig it,you will pay in the end-mike
SOURCE: FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
