U clean the lens and check it .then also it cant able to read the disk see this site to solve the problem.u can even check its spinning after u insert your disk if not the problem with your motor..
SOURCE: ps3 not reading blue ray dvds or ps3 games
You need to contact the manufacturer. (Call the 1-800 or W/e line)
They will ask you for the model number on your PS3. and provide instructions on how to locate it.
then they will tell you weather or not your under warranty still. DONT WORRY
from the sounds of this, this is a manufacturing problem. Instead of doing a recall like a respectable company, they sit around and when one of them calls in with problems THEY FIX IT FOR FREE.
they do this because most people figure once the warranty is void that there is nothing you can do.
You will recieve a "Refurbished" system in return for yours. IE someone else complained theres was broken and they fixed it for cheap and will send you this. (its fine they also give you a temporary warranty most of the time)
GL and Get in Contact With the PS3 People (idk who they are lol)
LITTLE TIP I know X Box 360 irregardless of lot number or warranty 95% of the time will just send you a refurbished one if you live in CANADA. (this is because of our "Extreme Environment")
(I asked what that was and they said the dust and waether and grass.)
