Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
