I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution...
(More)
I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution #1 in this page says "a bad cap in the power board, the can like device will have a puffed up top from venting the value is on the side, replace it". Where can I get this can like device? Thanks...
i have a tla-01511c 15.4" tv. i cannot program my universal direct tv remote to my tv using the...
(More)
I HAVE A TLA-01511C 15.4" TV. I CANNOT PROGRAM MY UNIVERSAL DIRECT TV REMOTE TO MY TV USING THE 0178 CODE GIVEN TO ME. ARE THERE OTHER CODES? I STILL HAVE TO USE MY POLOROID REMOTE TO POWER MY TV ON AND OFF. THE VOLUME AND CHANNEL WORK WITH THE DIRECT TV REMOTE BUT NOT THE TV POWER BUTTON.
my remote will not work? replaced batteries - have same tv in other room and that remote works fine...
(More)
my remote will not work? replaced batteries - have same tv in other room and that remote works fine with both TVs...this one wont work with either
low voltage outputs ok. missing one of the higher voltage outputs.Best info i can give as this is...
(More)
low voltage outputs ok. missing one of the higher voltage outputs.Best info i can give as this is long distant advice to my son.
the tv picture goes of and just the sound is left on.we dont know how to sort it and dont know what...
(More)
the tv picture goes of and just the sound is left on.we dont know how to sort it and dont know what button was pressed.thankyou kathleen
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
