This model doesn't have any A/V jacks. Many low-end RCA models didn't include any special features. They can only pick up signals over the antenna input. What you'll need to connect your DVD player is an RF converter, which takes the audio and video signals from the player and turns them into a channel 3 or 4 TV signal that the set can pick up.
RF converters aren't hard to find. Radio Shack, Sears and Wal-Mart all say they sell them, and you can certainly find them online. Hooking one up is just a matter of connecting the necessary cable to the player and TV, connecting the converter power and setting the output channel. Then put the TV on that channel and you're set. Unfortunately, this will give you lower picture and sound quality than
you get from a TV that allows direct A/V inputs, but it's the only
option.
SOURCE: Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
SOURCE: Where are jacks to hook up dvd
Hi, I downloaded the manual for this TV to make sure of its connectivity. The only connection the TV has is a coaxial connection for ant/cable which will accommodate cable, antenna, VCR, DTV. It does not accommodate sources without coaxial outputs such as most DVD players. However, there is a solution. Radio Shack, Best Buy, WalMart etc, all carry a device called an RF modulator that will convert the A/V outs from the DVD to coaxial. Here are a few links below of the device you will need to get you up and running.
http://www.radioshack.com/product/index.jsp?productId=2103095
http://www.walmart.com/catalog/product.do?product_id=9893723
http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&st=rf+modulator&lp=2&type=product&cp=1&id=1067388827858
SOURCE: have no remote trying to hook my dvd player to tv
Try the channel buttons and go below channel 2 or above 125 that`s usually where you will find the video input. Hope this will help.
