No its not the t-con. The t-con is only responsible for displaying an image. It will not affect the sound. Since you have no sound either you should shift your diagnosis to main audio/video board. You do not have to turn on any switch manually. The relays will turn themselves on if everything is perfect.
It depends. There is a micro-processor IC on it that is irreplaceable. As for your model number I do not remember seesing a 31MF231D. If its a 32MF231D, I have a comprehensive service manual that I can give you. It should make your job a lot easier. Ofcourse I will guide you if you need something. So the first thing you should check is the model number. A google search for your model returns hardly any results.
Thats not necessary. I will just upload it to mediafire and get you the link.
Here's the service manual
http://www.mediafire.com/?5y6kbv8cc32m33...
Oh, so you haven't checked all the caps? Yes that seems to be the problem. You have got the service manual now, there's a detailed schematic in it. Check the voltages and see if any of them are missing. As for the diode, you can just check if its shorted.
Ok. I do not advice replacing the diode with an inductor though. As you may know the diode will not allow the current to flow in reverse bias mode, where as an inductor has no such thing. Its just a temporary solution, I would say.
You are welcome. If you do get stuck somewhere. Let me know and I will see you through it.
On which board and which component?
Oh. Thats the one going to the inverter. I forgot to ask you do you have sound?
Well thats a tricky situation. What do you wanna do, try and replace the power board?
Well lets continue the diagnosis. Its a tricky situation. I do not want to take a chance and tell you to replace the wrong board. Reading page 70 I have seen that pin 6 has not function. Also by gray screen do you mean that the backlight is lit?
Oj. Just seen it and it confirms that its a power board issue. So I think you can go ahead and replace the power board.
Sure thing.
is there anything to replace on the main board? or is it pretty much a swap out and hope for the best?
its a 37mf231d, sorry for the confusion. I'll take any manual that will help. guessing gets expensive. Let me know how you can send the manual, and if I need to give you an email address
37mf321d
http://www.fixya.com/support/t2696949-ma...
This seems to be my same situation but it looks like he is recomending a replacement of an inductor with a diode? could this be right?
I replaced 5 caps, 2074, 2082, 2081, 2080,
Thank you for your great help
Working through the troubleshoooting and do not have voltage on pin 6
No voltage out of 1088 pin 6
not tested, I have it scattered across the living room floor. Cant bring up menu, channels, or volume bar
After two days Im at my end. Im open to suggestions. the power board sounds logical to me. is that what you would do
what controls the power to 6
yes backlight is lit, but cannot bring up the menu. power light is solid (not blinking) Page 90 chart show pin 6 with 2.6v and pin 7 with 6.7v. I've connected video feed to all inputs with no change
thanks will do and let you know how it turns out
