Computers & Internet Logo
Posted on Jun 16, 2008
Trying to get on the internet I have a toshiba laptop and it was being fixed by Micromedics and when it came back I can't connect to the internet. jpsew1
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 16, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
509
Points
16
What Toshiba laptop do you have and what is the operating system? It could just be your ethernet card that is not installed properly.
2answers
How do i fix my internet issue with Toshiba laptop
You may have virus. Try system restore to earlier date and perform a virus scan.
First thing is the operating system. What windows version you ae using has a lot to do with how to proceed. You need to look in device manager in the control panel to see what it says about your wireless device. Then you should check the error messages to see what they are
1helpful
How do I fix internet proxy settings
Most people don't need a proxy server unless it's in a corporate environment.
On your laptop, try going into your control panel -> Internet options -> Connections tab -> LAN Settings button and uncheck all of the boxes. Hit OK until you get back to the control panel. Try your internet and see if it works.
1helpful
My Toshiba NB205-N311/w will no longer connect to the internet. I have tried the Function F8F8 to ensure the wireless is on but nothing happens. The green bars all say I'm connected to my wireless network,...
Go to TOOLS-INTERNET OPTIONS. Go to the CONNECTIONS tab at the top. Go to the bottom where it says LAN SETTINGS. Make sure only AUTOMATICALLY DETECT SETTINGS IS checked and nothing else.
My toshiba laptop Satellite L25-S1194 wont connect to the internet. other laptops is able to connect.When viewing wireless network settings, I can see the laptop is receiving the signal, but unable to...
Is this the first time you are trying to connect to your Internet with that Toshiba laptop?
If that is your first time you need to call first your Internet Service Provider and check what can they do for you.
If there is no problem with you Internet Service Provider, try to press the FN+F8 keys these are the toggle keys to enable or disable your Wifi.
When you press those two keys observe the laptop if you will have a message that says Wireless Connection is On or Off. If it is off, try to press those two keys again to turn on the laptop.
I believe your laptop came with a Wireless On/Off switch, check that also if it is on there will be a light indicator for the Wireless Connection. It should be a steady light.
Now, if the wireless connection of your laptop is on and still you can't connect to your wireless connection, try to update the drivers for your Network Adapter.
Here's the link for the latest driver:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1124513&rpn=PSL2XU&modelFilter=L25-S1194&selCategory=3&selFamily=1073768663
You need to search for your operating system and choose the Wi-fi on all categories.
You need to save it first on the laptop and after that you will have an option to run it on the laptop. After the installation of new driver try to restart the laptop and try to connect to your Internet.
If that will not work.
You need to contact Toshiba technical support at
Toshiba Technical Support
800-247-7777
Hope this helps. :-)
I had to replace my harddrive on a toshiba laptop. I put the recovery disk in everything went good until I try to connect to the wireless internet. If I plug the usb cable in the laptop it works fine but...
A "Diagnostics" can identify the cause of the problem, or (errors) and try to correct, the "Internet" connection. Go, to: Control Panel, select "Network and Internet." Select, (“view network and task status”),choose a task”, to performed, from the (left) pane. You can start a quick diagnostic by clicking on the connection "diagram", Computer---WNC---Internet. “You can (setup) personal computer, internet settings.” I hope this Fix it.
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Cannot connect to internet
Check the hardware using the device manager to see if there is an issue with the drivers. You can hold the windows key and press pause break and device manager should show up. Look for any ! ? or other marks on the list.
No Internet No Disk for drivers
go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support#
select your product and download the drivers to your external drive
connect it to your friends laptop and install them, if you want it quicker just get the network drivers from the site, transfer and install then you can get all the other drivers directly to the laptop you are working on
hope that helps you, these are from the US site btw, if you want them for other locations (shouldn't make a difference) then go to toshiba.com and select your region
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
