HP Deskjet D4260 Printer Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ayellow light on the front panel is blinking and a message came on that the spoler is not working. What should I do
ONE-Touch-Solution
Level 3:
  • HP Master 1,679 Answers
  • Posted on Nov 04, 2010
ONE-Touch-Solution
HP Master
Level 3:
Answers
1679
Questions
Helped
405129
Points
5442
Remove the cartridges
Clean the contacts on cartridges with lint free cloth ( the golden contacts or electrical contacts )
Install the cartridge back in printer
Disconnect the USB cable of the printer and after 30 seconds re-connect
Click on the link to fix the spooler issue - Spooler Fix utility
I hope this will resolve the issue.
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
1helpful
Check print cartidge light keep blinking and the light on copies showing empty while there is paper in the tray
Issue: The Check Paper and Check Print Cartridge lights blinkIn this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : On
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : On
  • Color Start Copy light : On
Figure 79: The Check Paper and Check Print Cartridge lights are blinkingc00864299.gif
    hpweb_1-2_minus.gifCauseThe carriage is stalled or jammed. A message indicating that the carriage is stalled might appear on the computer.You might also experience the following symptoms:
    • The product will not print.
    • The carriage is stuck and does not move.
    • The product makes loud grinding noises.
hpweb_1-2_minus.gifSolutionsSolution one: Turn the All-in-One off and then on againFollow these steps to turn the product off and then on again.
  1. Press the On/Resume button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the On/Resume button (c01602202.gif ) to turn on the product.
  4. Check the lights on the control panel to make sure that they are no longer blinking.
  5. Try the intended task again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Make sure that the front panel overlay is installed correctlyIf the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay.If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
2helpful
2answers
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
The printert dos not respiond to any cartridge and dos blink at all /
Issue: All the lights blink In this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : Blinking
  • Black Start Copy light : Blinking
  • Color Start Copy light : Blinking
Figure 107: All the lights are blinking on the control panelc00864301.gif Solution one: Make sure that the front panel overlay is installed correctly If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins. NOTE: If you have already installed the front panel overlay, proceed to the next solution.
  1. Disconnect the power cord from the rear of the product.
    Please arte me Thanks Techbelkin
    TECHBELKIN ORIGINAL SOLUTION
  2. Locate the front panel overlay and peel off the paper backing to expose the adhesive as shown in the graphic below. Figure 108: Remove the paper backing from the front panel overlayc00005257.jpg
  3. Lift the scanner lid.
  4. Carefully line up and install the front panel overlay. Figure 109: Install the front panel overlayc00005258.jpg Figure 110: Correctly installed front panel overlayc00005259.jpg
  5. Reconnect the power cord to the rear of the product.
  6. Try the intended task again.
Solution two: Reset the All-in-One Follow these steps to perform a power reset. Step one: Perform a power reset
  1. Press the On/Resume button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on automatically, press the On/Resume button (c01602202.gif ) to turn the product back on.
Step two: Print a self-test report Follow these steps to print a self-test report.
  1. Load plain, white paper into the paper tray.
  2. Press and hold the Cancel button (c02517757.gif ), and then press the Start Copy Color button. The product prints a self-test report.
Solution three: Service the All-in-One If you have completed all the steps and are still experiencing a problem, continue to the Service the All-in-One section at the end of this document. Service the All-in-One If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
3answers
The error light came on and I don't know whats wrong
What is the error light
Step one: Identify the specific printing problemIf your All-in-One won't print, first you need to identify the specific issue or symptom. What exactly happens when you try to print? Do you see an error message or do the lights on the printer start blinking (flashing)? Does nothing happen at all? Follow these steps to identify your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step. Method one: Look for blinking lightsLook for any blinking lights on the front or top of the All-in-One. Sometimes just the power button can blink, or a small indicator light on the printer can blink, or a combination of buttons can blink all at once. Example indicator lights on the printer Attention lights Wireless indicator light Cartridge lights Error Lights c01890693.gif c01890694.gif c01890695.gif c01890697.gif c01890698.gif c01890699.gif c01890700.gif c01890701.gif Example blinking lights patterns
c01890702.gif Method two: Look for error messagesPrinting problems are usually accompanied by an error message of some sort, usually on the control panel display (if your All-in-One has one), or on your computer monitor. Check both places for specific error messages. Error messages might or might not be accompanied by an icon representing the error. Following are some examples of error messages you might see on your computer screen or control panel display.
  • c01890703.gif 'Printer is Offline '
  • c01890704.gif 'Align Cartridges '
  • c01890705.gif 'E ' (error condition)
  • c01890706.gif 'Document(s) pending ' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
1helpful
KODAK EASYSHARE 5100 SERIES
a blinking yel light w/ "F" on display means MEDIA SENSOR FAILURE
"P" PRINTHEAD FAILURE
"S" SCANNER FAILURE
k24674
Grand Canyon Tech
Grand Canyon Tech
