Belkin F5D7234-4 Router Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have F5D7234-4V1 with insight internet connection and i have win-xp laptop , ERROR MESSAGE - (windows cannot configured wireless ) tell me what to do - But unable to start WZC on my computer
Level 3:
  • Belkin Master 7,733 Answers
  • Posted on Nov 04, 2010
Belkin Master
Level 3:
Answers
7733
Questions
0
Helped
1865087
Points
21487
If you want to use Windows Wireless Zero Configuration to manage the wireless network, you will need to have Windows XP with service pack 2 as a minimum.
With Windows XP and SP2, you will need a Microsoft update for WPA2 that can be obtained from:
http://support.microsoft.com/kb/893357/en-us
After installation you will need to use the Windows Zero Config wireless configuration in the control panel to configure the adapter. WPA2 should now be available and work correctly.
Windows XP with Service Pack 3 and Windows Vista offer support for WPA2 without additional updates.
Just purchased a WGR614 wireless router for my dell laptop. the instruction manual only mentions connecting to external modem, what if you have a laptop with an internal modem, how do you connect? My...
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
I have configured my d link router and able to connect it with my win xp laptop and after i connect internet cable to the wireless router i am unable to access the internet through my win xp and win 7...
If initially the Win XP laptop was connected to internet at the cable/dsl modem, its MAC address would have been registered on service setup. If the router is now in place between the Win XP laptop and the cable/dsl modem, you would need to go on the Win XP laptop and log into the router as admin to clone the Win XP laptop's MAC address to the dlink router's WAN interface (internet facing side) so that the cable/dsl modem will see the previously registered MAC address and will enable the internet access.
I format my computer and install window after that internet not not works\r\nplease tell me how it will work
Reinstall the Driver for wired/wireless connection. Click on the links below to obtain the drivers that you need.
For Win XP Operating System Wired connection Click here.
For wireless connection drivers click on the links appropriately.
Broadcom Wireless LAN Driver
For Windows Vista (32-bit) click here.
For Windows XP click here.
Intel Wireless LAN Driver
For Win XP Operating System click here.
For any other drivers you need for your N100 Machine click here for the list.
Should you have any other questions just please leave a comment.
Cheers~
Dell Latitude E5400 internet connection problems
If you are not using it, uninstall Dell Control Point Connection manager, then the Window Wireless configuration will function normally
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
2answers
Can't connect to wireless router. Had internet till router changed. All other laptops in the house work fine. Diagnosis says windows is not managing the network, what happened?
when you try to connect to the wireless network, you are getting the message " windows can not configure the wireless network" or windows is not managing.
What is the Operatig system on the computer ?
If it is windows XP then you can switch over to windows utility.
for this you will need to start the wireless zero configuration.
If it is WINDOWS VISTA / 7, then windows will manage the network.
Click here for more information about routers and wireless network.
Epson sx515w wont fully install on my windows 7 laptop wirelessly
Look in http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/64f2f003-7c0b-4809-b376-e610b370fceb
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "Problem getting wireless Epson SX515W connected to laptop running Windows 7"
In my case I had the SX515W configured via USB with other computer with Win XP, and later working by WiFi.
With may new laptop with Win 7, I have the error with the NetSetup installation CD.
First I checked that it was possible to print via USB with the laptop, and after I added by wifi using the "add new printer wizard" as explain Quagmire69 in the link attached.
Good luck
2helpful
Wireless connection for Win 7
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Shared internet connection help!!!
are you using window xp for both pc?
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
