SOURCE: frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
SOURCE: scrolling arrows on my mouse pad on Aspire 5100 laptop not working
see this link, save me typing it again
http://www.fixya.com/support/t995556-mouse_pad_problem
SOURCE: I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
SOURCE: right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
